Hi All,
I have a Plex Media server set up and Plex Clients running on a number of devices; PC, ipad, iphone, Raspberry Pi and Raspberry Pi2
The channels work correctly on all of the clients I have except the Raspberry PI's both running RasPlex
(which is why I have posted this in the RasPlex forum rather than Channels forum)
It is BBC iplayer that is failing on the Pi's and I really want to get working.
(also CNN channel fails but Revision 3 channel works on the Pi's fine)
BBC iplayer loads all the pretty metadata (this is what makes RasPlex good for tellies) with no isssues but when you try to play (stream) it fails with media not found.
I can then use my ipad plex app or plex via ipad google to navigate to the same program on iplayer and then play successfully.
I have exactly the same issue on an old raspberry Pi and new Pi2 both running RasPlex.
Is latest iplayer known to be working on RasPlex versions below as of today? (I am presuming "yes" but BBC is known to break things and make(IMHO) unwise decisions :-) from time to time!)
I have downloaded/uninstalled/reinstalled the channels on PMS several times and reset bundles (services, framework etc)
I have latest official iplayer on my PM
iplayer seems to work very well on other clients but not at all on Rasplex.
PMS at 0.9.11.7.803-87d0708 - fresh install this weekend (insteady of an update) - wired fixed IP Ethernet to router
PI2 running 0.5.1 - reinstalled this weekend - wired Ethernet and accessing libraries very fast
Pi B+ running 0.4.1 (haven't bothered upgrading that yet!)- wireless access to libraries good enough
I believe I am hunting a rasplex problem/step I have missed rather than any PMS issue but happy to listen to those who know better!
So far RasPlex has been as simple as falling of a log...until iplayer!
I hope to hear from iplayer/Rasplex experts soon.
Rob.
