Hi Guys,
Is anyone else having issues with BBC 1 using HDHomeRun and Plex? We have no sound on this channel through plex, however, using the HDHomeRun app direct it works fine.
Server Version#: 4.33.1
Player Version#: AppleTV
Tuner Make/Model: HDHomeRun Quadro
Guide/Lineup name:
Using XMLTV?:
Channel number/Name: BBCOne - 001
Yes almost identical issue.
plexinc/pms-docker:latest as of writing
Apple TV
HDHomeRun CONNECT
BBC 1 North West
Good to know it is not me…
Wonder if support will answer this or if I am wasting my money on Plex Pass…
Dont have an Apple device so not sure where the option is on it
While playing BBC1, check which audio stream is playing, I have seen it mentioned before that sometimes the wrong one is playing
Yep I’ve had this problem for months. No server updates have fixed it.
I’m using a Windows 10 server with two WinTV QuadHD tuners. It’s the same on all tuners, and it’s only BBC1 (Yorkshire).
As Paul Salter has suggested the problem (at least for me) is that there are two audio streams, and Plex is picking the blank one instead of the correct one. It doesn’t matter whether I’m using Rokus or the Web App, it always picks the wrong audio stream.
I’d love to know what’s going on! I basically just watch BBC1 HD instead, but of course you don’t get local news on HD!
