Beta Invite not working
I just received the email that I was invited to the android beta but am getting the error ‘App not available for this account. Your account isn’t currently eligible for this app’s testing program.’ when clicking the link below.
https://play.google.com/apps/testing/com.plexapp.android
I have the same issue.
I’ll try to find out what is up.
Thanks!
Can you try again. It should be fixed
Still same problem.
I was just told it might take up to an hour to kick in. Let me know then if still not working.
I’m also having the same issue. Should I wait a little longer? Thanks.
Yeah please give it more time. Sorry about this.
Seems to be having the same problem. Have been trying sins last night.
This should of been fixed now and the link will work.
Over on the nvidia forums there is a post that says the latest beta has finally fixed the issues plaguing my shield. Can I please get signed up to use the beta? And does my PMS also need to be on beta channel? Or just the shield?
based on that nvidia link sounds like just the Android TV app you need. Info on beta sign up is here Join App Betas: Android (mobile), Android TV, Apple TV, iOS
It works now. Thanks!
I am having the same issue with the invite that I received
Same issue with me too…
Can you try again?
Sorry for the inconvenience!
I’m having this issue too :frowning:
Do you mind checking it again?
Works now, thank you!
