Better reordering of Recommendations
Edit: would have been nice to respond to this but you closed the thread to prevent it.
This is what was previously available in Manually Managed Home before it was removed, and was not widely used at all. This functionality will not be returning.
Manual management sucked, you should know, it was complained about in posts that you yourself responded to, not only here on this very forum but on Reddit and you’re surprised people were reluctant to use it? Maybe I should have been more clear in my post, because I was referring to doing this for each library type, not the same as how manual worked which places duplicates of each recommendation for each library, instead they would remain merged but just allowing us to re-order the recommendations.
Original post
It would be nice if we could reorder each recommendation for each library under home screen instead of having all recommendations for each library appear together.
So instead off
Continue Watching
TV Recently Added
TV Recently Released
Top Rated TV
Movie Recently Added
Movie Recently Released
Top Movies In
We could mix and match like so…
Continue Watching
TV Recently Added
Top Rated TV
Top Movies In
Right now it feels tedious because if I wanted to see recently added movies I’d have to spam click down to get to it or go to the movie library, or reorder my home screen so movie recommendations show first, but then if I did that I’d have the same issue for TV shows.
Right now I just limit my recommendation to recently added, but I would like to use others, especially with the new modern UI.
