Bibliotheque
Server Version#:
Player Version#: 1.41.8.983
Hello,
I would like to know if it’s possible to protect (with a password, for example) a folder in your library so that anyone can see it?
Hello,
I have submitted a request to authorize access. When I use the link, I constantly get this error.
Thank you for your reply.
You can protect your user account with a password and 2FA, as for specific folders no - but for libraries themselves, you can protect the contents of that library by not sharing it with other users that have access to your server.
My French isn’t great, but that screenshot looks like it’s saying you need to accept the invitation in order to gain access to this server, but your email doesn’t match who the invite was sent to.
I stream Plex to my Apple TV. The whole family has access to it. But what I’m looking for is to prevent people from watching only one library. I only stream to my Apple TV.
If your family is using your account, there won’t be anything you can do to restrict what they have access to. Likely the easiest thing to do here if I understand correctly would be to create individual Plex accounts for each member of your family and then add them to Plex Home for easier user switching. Then you can restrict each user account to only have access to the libraries you want them to.
  1. prevent other users to have access to your Plex account
  2. create either managed user accounts for your family members, or tell other users to create their own plex.tv user accounts.
  3. share only selected media to these other users https://support.plex.tv/articles/204232573-restricting-the-shares/
Ok, thank’s. I see
I restrict using labels.
I don’t understand
Check the link that @OttoKerner provided.
You can create and associate labels with movies and TV series. You can then restrict users’ access by only allowing those labels and/or excluding those labels.
