black bars top & bottom
Hi, i'm using a rasperry pi 2 and all is working fine. Except for one thing. Each time i'm starting a movie i must change the aspect ratio zoom or wide zoom. If not i always black bars.
I'd like to setup the zoom by default is it possible ? I have some choice in preference for to 4:3 aspet ratio but it doent work :(
any idea ?
thank you
any idea ?
thank you
this happened to me and it was because when I setup the screen calibration my "square" was way off, start by modifying that and see if it helps.
Actually came here because rasplex does not save my video settings. Everytime I play a video deinterlacing and scale mode is reset to default. Current PlexHT release does save this.
Have you raised an issue in GitHub?
@NedtheNerd which of the repos over there is the current one? I find the structure quite hard to understand...
Never mind, I found the guide sticky post here :-)
@taenzerme said:
Never mind, I found the guide sticky post here :slight_smile:
How? where is?
I have same problema.
@taenzerme said:
NedtheNerd which of the repos over there is the current one? I find the structure quite hard to understand…
Just select Issues from the sidebar at GitHub - RasPlex/RasPlex: Rasplex is a community driven port of Plex Home Theater for the Raspberry Pi.
Regards
Why not save configuration aspect ratio?
any? plex help me
bump
no help?
@daicon said:
any? plex help me
