No Zoom Option
I have a couple of rpi B+ models and have put rasplex on them.  I am loving the plexHT interface on such a low power machine, but one thing seems to be missing.  When watching a video on my x86 PC running plexHT, if I open the video options menu in the OSD, there is a slider to zoom the video to specific amounts.  The video OSD in rasplex has the view MODE options in the menu (stretch, normal, zoom etc..) but it's missing this slider.
I am running the newest 0.4.1 version on both pi's and I have tried re-imaging with no success.  I also tried every combination of different settings in the advanced video settings menu and couldn't get it to show up.
Was this something you guys removed from rasplex because of performance or something, or is it supposed to be there?
Found this by searching the forum.
https://forums.plex.tv/topic/68908-rasplex-adjust-aspect-ratio-or-zoom-level/?p=398616
Regards
Thank you Ned, I indeed have seen that post (I guess i should have mentioned it in my post), but it is unhelpful.  Unfortunately the setting he is talking about is completely different than the zoom I am referring to.  That setting is for zooming the entire plex interface, not videos.  Honestly I don't understand why that setting even exists, it doesn't fix overscan and just cuts off elements at the edge of the screen as it is increased.
The "zoom" I am referring to is accessed WHILE PLAYING A VIDEO, through what xbmc (on which plexHT is based) calls the "video OSD" menu.  This menu is accessed by pressing select while a video is playing and then scrolling over to the icon that looks like a TV (in the original skin).  Here is an example of that menu:
Note this is with the plex black edition skin but the zoom slider is missing on the official skin as well
This post, also in the rasplex forum, has an example of what the video OSD should look like with the zoom slider, although he is asking about customizing that menu.  You can see in my shot above, that slider is missing.
Note this is with the plex black edition skin but the zoom slider is missing on the official skin as well.
Suggest you file an issue on Rasplex Github.
Regards
