Hi there !
I'm trying to connect to sony sbh20 on rasplex. I can see the device in prefrenses>settings>bluetooth but i cannot connect to it!
can you please help me?
Thank you.
Hi there !
Thank you.
I was able to connect to the sbh20 I entered the passcode 0000 and the pairing was successful! BUT I have the following error : "Bluetooth input/output error" and so I get no sound over Bluetooth. I only get sound on HDMI. I really need bluetooth because I'm on a projector and the sound system is several feet away you see..
Any help appreciated
Thank you.
Did you ever up getting anywhere with this?
I would also like to set this up.
I am going to purchase some bluetooth headphones anyways but I was going to hold off just in case some might have a compatibility issue?
Does anyone know if bluetooth audio will work with rasplex?
Driver and devices support should be forwarded to OpenELEC guys as this is the OS we are using.
We try to keep up with following their versions. Maybe you could check on their forums if such a support is coming with OE 4.0.
If not maybe you wanna drop a feature request to them for this :)
