RaxPlex Bluetooth audio issues with Sony sound bar
I’m trying to use a Sony HT-CT370 sound bar as my audio using RasPlex. I have the following RasPlex version:
RasPlex (official) Version: 1.8.0.148-573b6d73
RasPlex git: e2efbe6dff28a97ec76f0db00073fa3d00b45584
I enabled Bluetooth from the RasPlex settings UI then paired RasPlex with the sound bar. so far so good. I can hear the UI ‘click’ sounds from it. But when I start to watch a movie, it only plays audio for say 1-2 seconds, then the audio is muted. the sound bar thinks it’s still connected (it has a solid blue light lit showing a BT connection), but there is no sound coming from it.
I logged in to RasPlex via ssh, it lists the device:
# bluetoothctl list
[NEW] Controller B8:27:EB:9E:EA:55 RasPlex [default]
[NEW] Device 9C:AD:97:34:24:49 SONY:HT-CT370
but then things turn strange:
[bluetooth]# info  9C:AD:97:34:24:49
Device  9C:AD:97:34:24:49 not available
[bluetooth]# list
[bluetooth]# quit
[DEL] Controller B8:27:EB:9E:EA:55 RasPlex [default]
but this happens all over again:
# bluetoothctl list
playing a bit more:
[bluetooth]# connect 9C:AD:97:34:24:49
Attempting to connect to 9C:AD:97:34:24:49
        Alias: SONY:HT-CT370
        Class: 0x240414
        Icon: audio-card
        Paired: yes
        Trusted: yes
        Blocked: no
        Connected: no
        LegacyPairing: no
        UUID: Audio Sink                (0000110b-0000-1000-8000-00805f9b34fb)
        UUID: A/V Remote Control Target (0000110c-0000-1000-8000-00805f9b34fb)
        UUID: A/V Remote Control        (0000110e-0000-1000-8000-00805f9b34fb)
        UUID: PnP Information           (00001200-0000-1000-8000-00805f9b34fb)
        Modalias: usb:v054Cp0996d0104
but maybe RasPlex is trying to connect at the same time
how can one debug thus more & make it work?
Akos
is your Pi a 3b or 3b+?
are you using wifi or lan?
are you using the built in bluetooth?
I never tried to connect a bluetooth soundbar but what I can tell you is that the built in bluetooth is garbage and should be avoided, specially if you are also using the wifi.
The only time I used a bluetooth speaker the delay was so horrible I discarded it intermediately
