I have a Pi3 attached to my TV using Rasplex 1.6.2
‘Out of the box’ I was amazed because I was able to connect my Bluetooth headphones (go into preferences and change audio settings to Bluetooth).
Anyway a couple of weeks ago although my headphones were connecting, I was getting no sound from them. Today I tried pairing a Bluetooth speaker - it connects ok but just like the headphones, I’m not getting any sound.
If anyone has any good ideas as to how to fix this, I would be most grateful.
Malcolm
Sounds like bluetooth isn’t selected in the audio output preferences any longer.
@benjaminwolf
Thank you for your reply, but it definitely isn’t that. I go into the audio output preference - change from HDMI to Bluetooth - the sound stops coming from my speakers, but no sound comes from the Bluetooth device (but the Bluetooth device is definitely connected).
@“Malcolm Clark” said:
@benjaminwolf
You may need to enable debug log, reboot, test, and upload it here.
@benjaminwolf
I decided to take the easy way out - re-flashed the SD card.
The Bluetooth sound is back working again, but not 100% I watched a 90 minute programme and (say) every 20 minutes or so, the sound completely dropped out for 2 or 3 seconds and then it came back again. Odd.
I watched another programme just now through the TV’s speakers and the sound was ok all the way through. I’m as certain as I can be that the problem has nothing to do with my server or the connection to it, so it must be down to the Raspberry Pi I guess. But not really sure how to pinpoint the problem.
This happenes to me alot. I think the linux Bluetooth driver is buggy. I had the same problem with an Amazon Fire and an Amazon Echo I was testing. Then there was a update and it was rock solid.
However I still have to reboot the C2 and rPi3 often when connected to the Echo for the same signal garble or loss.
Thank you @benjaminwolf I guess I’m going to have to live with it for now.
I’m really hoping that a future release will bring (a) a stable Bluetooth driver and (b) automatic Bluetooth switching so that when I turn my headphones on the Pi automatically transfers sound to the headphones (it does that with my Apple TV4, but then again the ATV4 has loads of other problems).
