ok so I’m trying to get my harmony hub working with this.
I can’t get past step two, I turn on the BT in the system settings and it doesn’t see any of my dongles. I have several different kinds and apparently none of them are compatible.
can I fix this? edit something, etc… or does anyone know of a working dongle that I can purchase?
Then once I get a working dongle, what should I set as the device in the harmony settings?
ok… well you would know so I’ll take your word for it. I found a couple articles floating around where the author says they’re using a bluetooth keyboard, but perhaps they’re mistaken or something, dunno.
openelec supports it, which I assume is why it’s in there, why does rasplex not? can it not be properly added? just seems like too much of a cop out to remove it, because having BT would be very awesome.
anyways, back on track, still need to get my harmony hub to work besides through CEC. I assume either Pi Board or Flirc? is there another good option, like an aux IR receiver (3.5mm jack) or anything else?
Have a look at the RemotePi Board from MSL Digital, supported in Rasplex.
@trumpy81 said:
I just installed the RemotePi on one of my RPi2’s and it works perfectly with my Harmony Ultimate One. It was super easy to set up and is very accurate, no double presses when you hit the button once for example.
It also allows you to turn off power to the RPi2 using the remote as well, no more pulling the plug or manually hitting a switch (if you have one).
I am very happy with it at least.
Can you tell me who you conifgured this please, what device did you add to the harmony?
many thanks
So i added Microsoft - Media Center PC device but this didnt work I am running latest rasplex. Just to comfirm you have this working without IR over IP? thanks for ya help
@trumpy81 said:
… the LED’s on the Pi and remote Pi are far too bright and to that end, I would like to see a dark tinted polycarbonate used instead of the clear.
The red light is the most annoying, you can turn this off by adding the following to /storage/.config/autostart.sh:
