Has anyone been able to successfully use the Harmony Smart Keyboard with their Pi2 and Rasplex? there are two choices to connect it to your Pi, bluetooth or with the provided USB dongle. This is one of my projects I am trying to take on tonight and I am not having any luck.
I figured if I get bluetooth or the USB to work then I can use the keyboard or my Ultimate remote to control Rasplex.
Any ideas?
BTW. I do have a bluetooth dongle that I was able to successfully pair to the keyboad but there is no feedback from the keyboard.
Hey Newbie,
i search the same for my RasPlex Testproject.
I use a USB Dongle Flirc, put it in the RasPi.
For the configuration the remote control use this:
https://flirc.zendesk.com/hc/en-us/articles/200712568-Logitech-Harmony-Remotes
It works good, i use this since 5 days!
I have only one small problem, i can't power off the RasPi with a button.
The XBMC config "Power off" dosen't work .
