Hi guys I have some questions regarding the playback of BluRay Rips through Rasplex on the Raspberry Pi Model B:
1. Is Rasplex able to playback BluRay rips (25-40 Mb/s bitrate) that use any of the h.264, mpeg-2 or vc-1 video codes smoothly, providing I purchase the relevant license keys? (i.e. no lag, stuttering, buffering etc.)
2. Is Rasplex able to passthrough audio that uses the any of the DTS-HD MA, Dolby TrueHD, Dolby Digital or LPCM audio codecs?
3. Does Rasplex support the playback of PGS subtitles and if so, is there a setting to have them on automatically.
hi,
this is not the droid you are looking for...
1. maybe, but i really doubt it
2. it will passthrough the dts core, though it my experience it stutters bad. dolby digital works for me.
3. yes. and yes.
- scott
hi,
3. yes. and yes.
- scott
There's hope then! Thanks for the response. I don't understand why it would struggle to passthrough even the DTS core though seeing as how it isn't actually doing anything to it. :s
Do you or anyone else have any suggestions on a device that could fit my needs?
1. yes if it`s .mkv h.264. if the file exceeds 23-24gb it has to buffer every 10-15 min.
2. the best thing is just to rip the normal DD or DTS audio.
3.no idea
