Browse in LiveTV Tab reports error
If there is already a thread that you know of, please share it or @Atomatth in it.
I’m not understanding what you mean here? Obviously if your main use case is to use Browse to set recording, then yes you wouldn’t be able to set recordings this way since Browse is not opening correctly. However, you should still be able to use the Guide, What’s On, or DVR Schedule tabs to manage DVR recordings.
Stating something is broken without any evidence or clear steps to what is broken isn’t helpful. Please let me know what I’ve missed so we can address it. This is clearly something that you’re passionate about resolving so help me help you. :plexheart:
This is what i see in Browse, i don’t use this function but it explain what is happening. @Atomatth
Do you need logs?
Guide works as intended on MacOS
Right, so this is the issue captured in the thread. See:
What I’m not understanding is the claim that DVR recordings are broken or impossible to schedule. Anything not related to the Browse page not loading is not related to this thread.
Expect the next PMS Beta release to include the fix for loading the Browse page. This was a PMS issue.
Here are some other posts that also discuss what appear to me to be a similar problem:
https://forums.plex.tv/t/not-able-to-search-for-programs-in-live-tv/925902
https://forums.plex.tv/t/plex-epg-is-not-searchable/924461
As you can see from these threads, a lot of users are reporting that searching for a program in the future is not possible. I reverted to the last workable version ( 1.41.7.9823) so I cannot test whether it is possible to even schedule recordings.
Even if it is possible to schedule recordings for those programs that show up in the guide (I cannot verify that this works), doing that for a program that is several days into the future could be quite tedious as one tries to find the program while manually scanning the Guide. And if the Guide still works as it has been in the past, doing that for more than a week in the future would not be possible since the guide cuts off at 7 days.
Maybe these are all unrelated, but the coincidences seem to suggest there might be a common cause and is worth further investigation.
I am the author of one of the posts linked by @ryrrah (My post is linked below.)
I am able to schedule a recording by scrolling to a program listing in the guide and scheduling the recording from there. The recording seems to take place without errors. However, searching the guide seems to be broken.
My server version is 1.41.8.9834-071366d65 installed from a .deb on Ubuntu 24.04.
Thanks for the help @ryrrah. I’ve combined the search related threads together and asking for logs. @rbrown if you could get your PMS logs shared there I would appreciate it.
I have been doing the following:
  1. Search for Colbert in search box.
  2. Receive Top results with a warning that some searches timed out.
  3. Click on the “View more results” button
  4. Select Live TV from the filters across the top and am told “No results found” (but there is no error indicated). However, “The Late Show with Stephen Colbert” is listed in the grid program guide.
As posted earlier: my server version is 1.41.8.9834-071366d65 installed from a .deb on Ubuntu 24.04.
The logs are attached.
Plex Media Server Logs_2025-07-14_15-24-14.zip (2.9 MB)
@ryrrah Thank you for this. Will consume as soon as I can.
Browse in v1.41.9.9961 is still broken. (PlexWeb v4.148.0)
Last working for me v1.41.7.9823.
Think we’re going to have to hold off any upgrades until we see it in the release notes.
Update: In the new beta v1.42.0.9975 Browse seems to be fixed…
Another annoying thing is that the filter isn’t remembered. (happened a few years ago)
Also, the order of the filters isn’t correct. The second one overrides/resets the first one.
…but this is maybe another story.
The UPDATE remains faulted.
The new beta v1.42.0.9975 has fixed the problem for me as well. Everything else seems okay. Windows 11, 64-bit
But what will be broken with that UPDATE? This is an all to repetitive story for the PLEX dev team. I guess since we already paid for our forever PLEX Pass we don’t matter to them. I’ve grown very weary of this treatment, unfortunately it appears to be the same everywhere.
[Req#960d] SQLITE3:0x1, 1, no such column: media_items.begins_at in “select metadata_items.id from metadata_items join metadata_items as parents on parents.id=metadata_items.parent_id join metadata_items as grandparents on grandparents.id=parents.parent_id where metadata_items.library_section_id in (2) and metadata_items.metadata_type=4 order by media_items.begins_at asc, metadata_items.id asc, media_items.width desc, metadata_items.originally_available_at asc, media_parts.id asc”
Got exception from request handler: sqlite3_statement_backend::prepare: no such column: media_items.begins_at for SQL: select metadata_items.id from metadata_items join metadata_items as parents on parents.id=metadata_items.parent_id join metadata_items as grandparents on grandparents.id=parents.parent_id where metadata_items.library_section_id in (2) and metadata_items.metadata_type=4 order by media_items.begins_at asc, metadata_items.id asc, media_items.width desc, metadata_items.originally_available_at asc, media_parts.id asc
I don’t see errors.
Maybe after Update to v1.42.0.9975, wait 4 minutes and do a EPG scan.
The update to v1.42.0.9975 seems to have fixed the problem that I reported when I started this thread. Searching on the EPG also seems to work, which was another problem noted in other threads. I tested it on an old MacMini. I’m waiting until I see more reports before I install it on my regular MacMini.
Agree confirmed! :+1:
BETA v1.42.0.9975-6b2b441e1 fixes the problem on mine.
