Hello,
Do you know any "magic" trick to navigate quickly in a section? I have 62 tv shows in one section and reaching the last one is a pane. There is no way to loop, no way to go faster than clicking 61 times to reach the last one.
Thanks.
Hello,
Thanks.
Grid view?
Hello,
Thanks.
Really no need to click 61 times, just hold the down button, and watch it fly :) The longer you hold it the faster it scrolls. I can get to the bottom of a list with 250 items in it in about 4 or 5 seconds.
I'm sure I have tried with pushed button. I'll try again later. Thanks.
--------- Update ---------
I tested and it works perfectly for movies. For TV Shows, it slows down after few shows.
Which view type, list or bookcase?
List view.
