I can’t access my Plex server since moving to Orbi server through SKY. I understand I can’t put SKY Hub in bridge mode so I’m toying with the idea of purchasing a BT modem via eBay. If I do this how easy is the set up or is it a simple plug and play type thing?
I had previously used Airport express and had no issues accessing plex but as orbi is a router I assume that’s why I’m having issues.
Thanks. The rule says that it allows all connections from Plex Server.
It’s weird as it says that it’s not connected for remote access but when I try Plex on mobile network it works. I’ve had this before and it eventually stops working.
