[BUG #2] Android Beta 7.24.0.13291
Server Version#: 1.17.0.1841
Player Version# : Android Beta 7.24.0.13291
Second issue with this release, when playing from a music playlist , when you tap the shuffle icon, the first song it chooses comes on screen, but while loading the song that plays is not what is showing on the screen (or the metadata it transfers via bluetooth to either a car stereo or bluetooth watch for example) after first song plays the info and song match up but not the first song.
I have a screen capture showing this happening but it’s too large to upload.
Will be happy to provide logs or the screen capture if/when a plex employee actually acknowledges they read this post and request them. :crossed_fingers::crossed_fingers: (twice for more luck if an plex employee will even care)
Sorry we missed this one. We generally check the Player Beta section for beta issues. I believe the shuffle issue should be resolved in the latest beta.
Thank you, sorry it was in the wrong category. Just way too many places to put posts.
All good, and yeah it can be difficult to see everything :eyes:
The other issue you’ve reported (Podcast progress issues) is under investigation.
@Forkboy As @SamFromPlex said, the playlist issue should be fixed in latest beta. Please take a look to it and if it’s fixed, mark this post as solved. Thanks!
