Android sync'ed playlist not working
I notice it recently, the music playlist I sync’ed to my android phone it stop working.
When I click the Play icon on the offline playlist the playlist is not full playlist.
If I click on the song from playlist it doesn’t play next song. It only adds 1 song to the playlist.
I think after the App update recently the playlist is broken. Or is there a way to fix this?
I’ve uninstall/reinstall the app and delete and re-sync the playlist.
Regards,
D
Yup same issue I have here, and shuffle only plays the first 50 or so beginning songs in a sync’ed playlist of 300 or so, and shuffling again plays the same songs but in a different order.
-Also deleted all sync’ed content and reinstalled the app, doesnt fix it.
I’m glad i’m not the only one with this issue. But seems like no one can fix this issue.
Same problem, been looking for a fix.
Ditto. Tried on a few old phones, and the same issue happend. But on my main phone, it seems to work ok. I’ve uninstall and reinstalled the app, deleted all sync content…and all cached data for Plex, and it didn’t fix the issue. All phones I tested were Android.
Oddly enough, the entire playlist shows as synced over, but only the first 50 or songs rotate through shuffle. I can view the whole playlist and select one that doesn’t play in the shuffle, but it only plays that song as if it’s the only one in the playlist.
Happy to report that the most recent Plex app for Android fixed the issue. Thank much Plex! :slight_smile:
