[Bug] Adding edition data to filename does block a successfull re-match
I think this is a little bit tricky to track. So please have a look at the example below… To understand what happens I need to explain that I do rename content on disk with a script after adding or changing content. I do use the following pattern for movie files:
/Moviename (2022)/Moviename (2022) {imdb-1234567} {Edition data}.mkv
Here we go:
  1. I put new content in the library. It’s named:
/Moviename (2022)/Moviename (2022).mkv
  1. The scanner runs, matches the new content and adds it to the library. → ok!
  2. My script runs and renames it to:
/Moviename (2022)/Moviename (2022) {imdb-1234567}.mkv
  1. The scanner runs and does a successful re-match → ok!
  2. Now I manually change the edition field in the Plex Web-App to “Edition data”
  3. My script runs and renames the file to:
  1. The scanner runs, adds the content as new (no re-match here) and the edition data is lost → Wrong, bug
I think this is a bug because adding the IMDB-ID to the filename still does a successful re-match. But adding the edition tag to that same filename (with the IMDB-ID still in place) does not re-match.
I can reproduce that at will.
Thanks for listening.
Above is wrong…
It’s {edition-data}
Sorry, don’t understand what you are saying. My “Edition data” is just text like “Director’s Cut”. Simply an example text to explain it to you. Let’s take a real world example:
/Total Recall (2012)/Total Recall (2012) {imdb-tt1386703} {Extended Directors Cut}.mkv
Scanner will not re-match that and create a new entry instead. At this point the edition text is lost in the database obviously.
Edit: Found it. Need to add edition- in front. Is this new?
Nope, always been like that.
Ref: https://support.plex.tv/articles/naming-and-organizing-your-movie-media-files/#toc-2
