Any reply please Plex ?
Also note as per my other report the latest beta cannot be downloaded…
updated client to last version. same for pms windows server. issue still there after end 2021(october)
last version without problem client side is always this
com.plexapp.android_8.23.1.28053-829872465_minAPI23(arm64-v8a)(nodpi)_apkmirror.com
link to download here : Microsoft OneDrive - Access files anywhere. Create docs with free Office Online.
FIX IT PLEASE ![]()
Android mobile v9 beta seems OK so far for me, still testing though…
could you please tell me exactly plex app version? i mean 30.0.x etc etc
9.0.0.31509
many thanks ![]()
Still broken still no response.
Feel like the Android client is abandoned.
Latest beta works fine for me
also download feature not work. it dowload things but crash at the end
The last Beta also fixed it until it didn’t. Going to bump these endlessly until its fixed or we get a response. For some reason rolling back to earlier versions never works on my Firestick and I’m not even going to try getting a beta running. This would be no big deal if this issue was temporary. At this point it feels permanent.
This is ridiculous. Long history of the app working perfectly fine then pointless updates breaking it.
i’ve just tried out last stable apk version on play store. 9.1.0.32210
it works fine. if i click auto convert it doesn’t go fast as hell. is fine.
try it out.
if i can, i hope they fix soon download feature broken and add these 2 things
OK, if you think that will help your call.
It’s fine for me.
