all my setup is as default since. i uninstall every release and install the new one. login up to my server
here are the setup
iām in the same network, NOT remote. on wifi
is a simple 720p h.264 aac
trascoding
Just to update, it does seem a lot better, but I see the same faults on mobile as I do on my FireTV stick with the same files as per Android: New video demuxer for improved playback - #12 by e10kstarfire
@sixones Happening on the shield as well, with current beta. Will this build load on there? May be a little different as I have to force transcode on there to fix the double speed problem.
Any update on getting this fixed please Plex support?
i have installed the version 8ā¦23.1 since ages. lol
This is a Biggy with numerous family having the issue on different devices. Please have a look at it guys.
Latest beta seems to resolve this if you havenāt tried it yet.
confirmed. 8.30.0(beta) seems fine. finally. more than 3 months
Hallelujah
I tried to update to beta last week, Google Play just didnt seem to update and android clients. But today, trying āwatch from beginningā worked for the first time, so I wonder if beta has be pushed to prod?
I need to check my client versions and see if things are now fixed properly!
Where can you get the beta for android? I donāt see it listed under the plex pass downloads.
https://play.google.com/apps/testing/com.plexapp.android
But the fix is now in public version
On beta i tried 8.30.0.31021 and the issue are again here when click automatically convert.
Someone can confirm?
On this release
Was all OK
Please check and fix once for all
anyone else noticed the issue reapperared on lastest beta?
Yes, itās broken AGAIN ![]()
I really donāt understand why Plex donāt run apps through test suites before releasingā¦
iāll stick with 8.23( 8.23.1.28053) version that is the last one without problem
iām tired of this.
i hope they donāt force me to update app client for newer server version restriction
before they DEFINITELY FIX this ISSUEā¦that is ongoing for AGES
Same problem here. Samsung Galaxy S8 (yes, an āoldā phone now) on Android 9. App version 8.29.1.30697 and running a server on a QNAP TS-451+ with QTS 5.0.0.1932 and Plex 1.25.6.5577.
I have tried turning the server side āconvert automaticallyā on and off, and it makes no difference. If the video plays from the start, itās usually okay. If resuming, forget it; it plays as fast as it can.
Any reply Plex?
You fixed it, then broke it again.
Running latest beta 8.31.0.31215 on Pixel 3a and playback speed is double speed.
As before setting āAutomatically adjust qualityā to off resolves.
