[BUG] - DVR fails to load EPG after 1% in PMS 1.15.8.1198
Server Version#: 1.15.8.1198 (Nvidia Shield)
See attached log!
Plex Media Server.log (743.4 KB)
Thanks for the log
There appears to be an issue with the area GBR-1007509
Managed to get the lineup with different region code
We are looking into the issue
Is this a new DVR ? Any change in setup with regards to the area / source of guide ?
And when did it work ok before?
I am getting the same error in my logs. I assume 2 builds ago this worked just fine and I did not have any issues that I know of. This has been set up for a long time and I only record like one show a week. This has not been changed in like a month from when I set up that one show.
Plex Media Server.log (53.0 KB)
Nope, it’s an existing DVR that was working fine… No change in setup other than upgrading PMS to 1.15.8.
Worked fine before that.
I have just tried the request and managed to get it to work. Could you do a refresh again and send me a new log file with debug enabled
Also can you do an nslookup tmsapi.plex.tv and let me have the result
Here is the nslookup:
Non-authoritative answer:
Addresses: 2606:4700::6812:9d29
2606:4700::6812:9c29
104.18.157.41
104.18.156.41
Aliases: tmsapi.plex.tv
And here is the new log file… it seems like it still failed.
Plex Media Server.log (259.9 KB)
PLEASE let me or anyone else know if you need anything else!
Same nslookup results for me. EPG refresh now seems to be working though (albeit very slowly!).
I am not seeing any change. It did get to 3% but failed with the following message.
ERROR - EPG: received HTTP response of 404 from request to https://tmsapi.plex.tv/v1.1/lineups/USA-OTA80017/grid?api_key=xxx&endDateTime=2019-06-07T06%3A00Z&imageSize=Ms&imageText=false&startDateTime=2019-06-07T00%3A00Z
WARN - EPG[onconnect]: Failed to load EPG.
@DavidAndAndrea @ASiDiE
There appears to be a problem with caching
A change has just been made
Could you please both try to refresh the guide now
Sa2000,
Here is the latest log but it did seem to complete. Very slow but nobody should really care how long it takes at this point.
There are some failures in the logs but those were from before. I did this test within the last 45 min.
Plex Media Server.log (784.9 KB)
Sorry can’t use the logs - debug logging disabled. But you are right there are no errors in last 45 minutes
Do expect it to be slower as caching has been disabled
Sorry about that… Just did it again and it was a lot faster.
Here is the log
Plex Media Server.log (923.8 KB)
Looks good. zero errors. Completed in under 7 minutes
Jun 06, 2019 13:28:52.027 [27563] DEBUG - Activity: updated activity 5d4c8311-49d4-4c1e-b0df-54238f5558db - completed 0% - Refreshing guide data
Jun 06, 2019 13:35:28.069 [24517] DEBUG - Activity: updated activity 5d4c8311-49d4-4c1e-b0df-54238f5558db - completed 100% - Refreshing guide data
Jun 06, 2019 13:35:28.372 [24517] DEBUG - EPG[onconnect]: Total time to load EPG was 396.2 (HTTP details cached 99.8%, CloudFlare grid cached: 0.0%, 0 HTTP errors)
