BUG: DVR setting with two devices, editing channels
Server Version#: 1.42.1.10060
Tuner Make/Model: HD Homerun & Xteve
Using XMLTV?: Yes
since a couple of weeks, when I setup my DVR (Xteve tuner + HD Homerun tuner) I find problems.
I can define first device with no problem, but when I add the second one, channel setup does not work. Instead of offering all the channels for the Guide, it offers the list of guides!!! And obviously you cannot select them.
Everything works according to the first setup, but there’s no way to change settings!!
It’s broken, it’s clear. It must be fixed in next versions…
Any safe version with this working? (I had this setup for years without any problems, editing channels several times per week)
