Bug - Freebase Agent - Localized Titles option doesn't work
An image says more than 1000 words
When Harry met Sally.
1. Filename has the spanish title (Cuando Harry encontró a Sally)
2. Library has selected Spanish as language of course, and the localized title option is marked. The library is new, I created a new folder with 3 fims as test for this
3. It founds the film, and it assigns the Spanish description (it's taking the spanish metadata!) and the Spanish poster, good.
4. But somehow it uses the original title instead of the localized.
5. This happens with all the movies, this one is just an example.
Any ideas?
Hi!
You're not doing anything wrong. I just checked the title "When Harry Met Sally" and even for Spanish it's listed on Freebase with the English title:
You can try and use The Movie Database agent as the primary agent for your movies section. With the section language set to Español this gave me the result you are looking for.
Well, thanks for the answer! The lack of not only replies but views of the thread was discouraging. I will experiment a bit more.
How do you know the correct xml to look at, btw? looking at the plex log first?
Hi! Yes, after creating the library or by doing a Fix Incorrect Match and then look at the log com.plexapp.agents.imdb.log
