Server Version#:1.13.5.5332-21ab172de
Player Version#: Chrome, Plex media player for windows, Plex media player for android
I have been able to reproduce this issue on multiple physical servers. reformatted and issue still presents itself on a fresh windows install. Issue presents itself in Ubuntu Linux. The issue seems to present itself more often on older or slower generation quicksync enabled intel chips.
Problem: Starting multiple transcodes simultaneously with Hardware transcoding enabled seems to cause plex to become unresponsive, the logs below are the logs captured right before / during a crash. During this unresponsiveness plex is running, transcoders are running, but the clients see a spinning wheel. No new transcodes can be started and everything else stops working until you manually kill plex and restart it.
Blockquote
Sep 25, 2018 12:29:03.821 [1872] INFO - Plex Media Server v1.13.5.5332-21ab172de - Microsoft PC x64 - build: windows-i386 english - GMT -07:00
Sep 25, 2018 12:29:03.821 [1872] INFO - Windows version: 10.0 (Build 17134), language en-US
Sep 25, 2018 12:29:03.821 [1872] INFO - 8 4008 MHz processor(s): Architecture=0, Level=6, Revision=24067 Processor Identifier=Intel64 Family 6 Model 94 Stepping 3, GenuineIntel
Sep 25, 2018 12:29:04.337 [3708] INFO - OCSP: Successfully retrieved response from cache.
Sep 25, 2018 12:29:06.992 [10956] INFO - LibraryUpdateManager path watching is disabled
Sep 25, 2018 12:29:09.508 [9044] INFO - Sync: downloaded 0 sync list(s) with 0 sync items(s): 0 new, 0 updated, 0 deleted
Sep 25, 2018 12:29:16.119 [8108] WARN - NAT: PMP, got an error: NATPMP_ERR_RECVFROM.
Sep 25, 2018 12:29:26.242 [8136] WARN - NAT: PMP, got an error: NATPMP_ERR_RECVFROM.
Sep 25, 2018 12:29:27.522 [6760] WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (eda6dfa8-a41a-4350-ab8a-37c71e863ffd, expected 4eb313b1-e188-49fa-b737-00f00b8fc2fe)
Sep 25, 2018 12:29:45.034 [10428] ERROR - Extras: Preroll file didnāt exist or couldnāt be read: āā.
Sep 25, 2018 12:29:45.534 [10428] INFO - [FFMPEG] - Initialized an internal MFX session using hardware accelerated implementation
Sep 25, 2018 12:29:49.621 [2660] ERROR - Extras: Preroll file didnāt exist or couldnāt be read: āā.
Sep 25, 2018 12:29:55.526 [4868] ERROR - [Transcoder] [h264_qsv @ 037ea1c0] Error during encoding: device failed (-17)
Sep 25, 2018 12:29:55.526 [7156] ERROR - [Transcoder] Video encoding failed
Sep 25, 2018 12:29:56.728 [10372] ERROR - [Transcoder] Could not write header for output file #0 (incorrect codec parameters ?): No such file or directory
Sep 25, 2018 12:29:56.728 [7156] ERROR - [Transcoder] Error initializing output stream 0:0 ā
Sep 25, 2018 12:30:08.304 [2660] ERROR - Extras: Preroll file didnāt exist or couldnāt be read: āā.
Sep 25, 2018 12:30:09.678 [10372] ERROR - [Transcoder] [h264_qsv @ 0377a240] Error during encoding: device failed (-17)
Sep 25, 2018 12:30:09.678 [2184] ERROR - [Transcoder] Video encoding failed
Sep 25, 2018 12:30:36.547 [10372] ERROR - Extras: Preroll file didnāt exist or couldnāt be read: āā.
Sep 25, 2018 12:30:37.609 [10372] ERROR - [Transcoder] [h264_qsv @ 0205a200] Error during encoding: device failed (-17)
Sep 25, 2018 12:30:37.609 [2660] ERROR - [Transcoder] Video encoding failed
Sep 25, 2018 12:31:05.806 [4868] ERROR - [Transcoder] Could not write header for output file #0 (incorrect codec parameters ?): No such file or directory
Sep 25, 2018 12:31:05.806 [1468] ERROR - [Transcoder] Error initializing output stream 0:0 ā
Sep 25, 2018 12:31:06.415 [2184] ERROR - [Transcoder] Could not write header for output file #0 (incorrect codec parameters ?): No such file or directory
Sep 25, 2018 12:31:06.415 [1468] ERROR - [Transcoder] Error initializing output stream 0:0 ā
Sep 25, 2018 12:31:07.540 [7156] ERROR - [Transcoder] [mp4 @ 0410bfc0] Application provided duration: -16 / timestamp: 204864568 is out of range for mov/mp4 format
Sep 25, 2018 12:31:07.790 [10372] ERROR - [Transcoder] [mp4 @ 0410bfc0] Application provided duration: -16 / timestamp: 204911672 is out of range for mov/mp4 format
Sep 25, 2018 12:31:08.055 [1468] ERROR - [Transcoder] [mp4 @ 0410bfc0] Application provided duration: -16 / timestamp: 204960808 is out of range for mov/mp4 format
Sep 25, 2018 12:31:08.337 [1068] ERROR - [Transcoder] [mp4 @ 0410bfc0] Application provided duration: -16 / timestamp: 205007912 is out of range for mov/mp4 format
Sep 25, 2018 12:31:08.711 [2184] ERROR - [Transcoder] [mp4 @ 08498980] Application provided duration: -16 / timestamp: 160893992 is out of range for mov/mp4 format
Sep 25, 2018 12:31:08.774 [4868] ERROR - [Transcoder] [mp4 @ 0410bfc0] Application provided duration: -16 / timestamp: 205057096 is out of range for mov/mp4 format
Sep 25, 2018 12:31:09.024 [4868] ERROR - [Transcoder] [mp4 @ 0410bfc0] Application provided duration: -16 / timestamp: 205104200 is out of range for mov/mp4 format
Sep 25, 2018 12:31:09.336 [2184] ERROR - [Transcoder] Could not write header for output file #0 (incorrect codec parameters ?): No such file or directory
Sep 25, 2018 12:31:09.336 [7156] ERROR - [Transcoder] Error initializing output stream 0:0 ā
Sep 25, 2018 12:31:09.852 [1468] ERROR - [Transcoder] [mp4 @ 0410bfc0] Application provided duration: -16 / timestamp: 205247528 is out of range for mov/mp4 format
Sep 25, 2018 12:31:10.117 [1468] ERROR - [Transcoder] [mp4 @ 0410bfc0] Application provided duration: -16 / timestamp: 205296680 is out of range for mov/mp4 format
Sep 25, 2018 12:31:10.617 [7156] ERROR - [Transcoder] Could not write header for output file #0 (incorrect codec parameters ?): No such file or directory
Sep 25, 2018 12:31:10.617 [4868] ERROR - [Transcoder] Error initializing output stream 0:0 ā
Sep 25, 2018 12:31:10.633 [7156] ERROR - [Transcoder] [mp4 @ 0410bfc0] Application provided duration: -16 / timestamp: 205392952 is out of range for mov/mp4 format
Sep 25, 2018 12:31:10.852 [1468] ERROR - [Transcoder] [mp4 @ 0410bfc0] Application provided duration: -16 / timestamp: 205440056 is out of range for mov/mp4 format
Sep 25, 2018 12:31:11.227 [2660] ERROR - [Transcoder] [mp4 @ 0410bfc0] Application provided duration: -16 / timestamp: 205489208 is out of range for mov/mp4 format
Sep 25, 2018 12:31:11.461 [1468] ERROR - [Transcoder] [mp4 @ 0410bfc0] Application provided duration: -16 / timestamp: 205536328 is out of range for mov/mp4 format
Sep 25, 2018 12:31:11.742 [1468] ERROR - [Transcoder] [mp4 @ 127db180] Application provided duration: -16 / timestamp: 206783560 is out of range for mov/mp4 format
Sep 25, 2018 12:31:11.758 [7156] ERROR - [Transcoder] [mp4 @ 0410bfc0] Application provided duration: -16 / timestamp: 205585480 is out of range for mov/mp4 format
Sep 25, 2018 12:31:11.805 [2660] ERROR - [Transcoder] [mp4 @ 08498980] Application provided duration: -16 / timestamp: 161037368 is out of range for mov/mp4 format
Sep 25, 2018 12:31:12.008 [1468] ERROR - [Transcoder] [mp4 @ 127db180] Application provided duration: -16 / timestamp: 206832712 is out of range for mov/mp4 format
Sep 25, 2018 12:31:12.117 [1468] ERROR - [Transcoder] [mp4 @ 0410bfc0] Application provided duration: -16 / timestamp: 205632584 is out of range for mov/mp4 format
Sep 25, 2018 12:31:12.242 [1468] ERROR - [Transcoder] [mp4 @ 127db180] Application provided duration: -16 / timestamp: 206879800 is out of range for mov/mp4 format
Sep 25, 2018 12:31:12.570 [2660] ERROR - [Transcoder] [mp4 @ 127db180] Application provided duration: -16 / timestamp: 206928952 is out of range for mov/mp4 format
Sep 25, 2018 12:31:12.789 [12256] ERROR - [Transcoder] [mp4 @ 0410bfc0] Application provided duration: -16 / timestamp: 205728824 is out of range for mov/mp4 format
Sep 25, 2018 12:31:13.070 [12256] ERROR - [Transcoder] [mp4 @ 08498980] Application provided duration: -16 / timestamp: 161086520 is out of range for mov/mp4 format
Sep 25, 2018 12:31:13.179 [7156] ERROR - [Transcoder] [mp4 @ 0410bfc0] Application provided duration: -16 / timestamp: 205775944 is out of range for mov/mp4 format
Sep 25, 2018 12:31:13.195 [12256] ERROR - [Transcoder] [mp4 @ 127db180] Application provided duration: -16 / timestamp: 207023176 is out of range for mov/mp4 format
Sep 25, 2018 12:31:13.460 [2660] ERROR - [Transcoder] [mp4 @ 127db180] Application provided duration: -16 / timestamp: 207072328 is out of range for mov/mp4 format
Sep 25, 2018 12:31:13.476 [0608] ERROR - [Transcoder] [mp4 @ 0410bfc0] Application provided duration: -16 / timestamp: 205825096 is out of range for mov/mp4 format
Sep 25, 2018 12:31:13.757 [12256] ERROR - [Transcoder] [mp4 @ 127db180] Application provided duration: -16 / timestamp: 207119432 is out of range for mov/mp4 format
Sep 25, 2018 12:31:13.773 [7156] ERROR - [Transcoder] [mp4 @ 0410bfc0] Application provided duration: -16 / timestamp: 205872184 is out of range for mov/mp4 format
Sep 25, 2018 12:31:14.038 [0608] ERROR - [Transcoder] [mp4 @ 127db180] Application provided duration: -16 / timestamp: 207168584 is out of range for mov/mp4 format
Sep 25, 2018 12:31:14.054 [10428] ERROR - [Transcoder] [mp4 @ 0410bfc0] Application provided duration: -16 / timestamp: 205921336 is out of range for mov/mp4 format
Sep 25, 2018 12:31:14.741 [10428] ERROR - [Transcoder] [mp4 @ 08848a40] Application provided duration: -16 / timestamp: 95421496 is out of range for mov/mp4 format
Sep 25, 2018 12:31:14.960 [1068] ERROR - [Transcoder] [mp4 @ 0410bfc0] Application provided duration: -16 / timestamp: 206062648 is out of range for mov/mp4 format
Sep 25, 2018 12:31:15.054 [12256] ERROR - [Transcoder] [mp4 @ 127db180] Application provided duration: -16 / timestamp: 207311944 is out of range for mov/mp4 format
Sep 25, 2018 12:31:15.226 [12256] ERROR - [Transcoder] [mp4 @ 0410bfc0] Application provided duration: -16 / timestamp: 206111800 is out of range for mov/mp4 format
Sep 25, 2018 12:31:15.257 [1468] ERROR - [Transcoder] [mp4 @ 08498980] Application provided duration: -16 / timestamp: 161182760 is out of range for mov/mp4 format
Sep 25, 2018 12:31:15.382 [12256] ERROR - [Transcoder] [mp4 @ 127db180] Application provided duration: -16 / timestamp: 207361096 is out of range for mov/mp4 format
Sep 25, 2018 12:31:15.507 [7156] ERROR - [Transcoder] [mp4 @ 0410bfc0] Application provided duration: -16 / timestamp: 206158904 is out of range for mov/mp4 format
Sep 25, 2018 12:31:15.585 [7156] ERROR - [Transcoder] [mp4 @ 127db180] Application provided duration: -16 / timestamp: 207408200 is out of range for mov/mp4 format
Sep 25, 2018 12:31:15.772 [12256] ERROR - [Transcoder] [mp4 @ 0410bfc0] Application provided duration: -16 / timestamp: 206208056 is out of range for mov/mp4 format
Sep 25, 2018 12:31:15.929 [7156] ERROR - [Transcoder] [mp4 @ 127db180] Application provided duration: -16 / timestamp: 207457352 is out of range for mov/mp4 format
Sep 25, 2018 12:31:16.085 [12256] ERROR - [Transcoder] [mp4 @ 08848a40] Application provided duration: -16 / timestamp: 95470648 is out of range for mov/mp4 format
Sep 25, 2018 12:31:16.600 [2660] ERROR - [Transcoder] [mp4 @ 127db180] Application provided duration: -16 / timestamp: 207551560 is out of range for mov/mp4 format
Sep 25, 2018 12:31:16.663 [2184] ERROR - [Transcoder] [mp4 @ 0410bfc0] Application provided duration: -16 / timestamp: 206351416 is out of range for mov/mp4 format
Sep 25, 2018 12:31:16.913 [12256] ERROR - [Transcoder] [mp4 @ 127db180] Application provided duration: -16 / timestamp: 207600712 is out of range for mov/mp4 format
Sep 25, 2018 12:31:16.944 [1468] ERROR - [Transcoder] [mp4 @ 0410bfc0] Application provided duration: -16 / timestamp: 206398520 is out of range for mov/mp4 format
Sep 25, 2018 12:31:17.225 [4868] ERROR - [Transcoder] [mp4 @ 127db180] Application provided duration: -16 / timestamp: 207647800 is out of range for mov/mp4 format
Sep 25, 2018 12:31:17.459 [0608] ERROR - [Transcoder] [mp4 @ 0410bfc0] Application provided duration: -16 / timestamp: 206494760 is out of range for mov/mp4 format
Sep 25, 2018 12:31:17.912 [1468] ERROR - [Transcoder] [mp4 @ 127db180] Application provided duration: -16 / timestamp: 207744040 is out of range for mov/mp4 format
Sep 25, 2018 12:31:17.959 [1468] ERROR - [Transcoder] [mp4 @ 08848a40] Application provided duration: -16 / timestamp: 95517752 is out of range for mov/mp4 format
Sep 25, 2018 12:31:18.069 [10428] ERROR - [Transcoder] [mp4 @ 0410bfc0] Application provided duration: -16 / timestamp: 206591032 is out of range for mov/mp4 format
Sep 25, 2018 12:31:18.194 [2660] ERROR - [Transcoder] [mp4 @ 127db180] Application provided duration: -16 / timestamp: 207793192 is out of range for mov/mp4 format
Sep 25, 2018 12:31:18.334 [2660] ERROR - [Transcoder] [mp4 @ 0410bfc0] Application provided duration: -16 / timestamp: 206640184 is out of range for mov/mp4 format
Sep 25, 2018 12:31:18.475 [1068] ERROR - [Transcoder] [mp4 @ 127db180] Application provided duration: -16 / timestamp: 207840296 is out of range for mov/mp4 format
Sep 25, 2018 12:31:18.647 [2660] ERROR - [Transcoder] [mp4 @ 0410bfc0] Application provided duration: -16 / timestamp: 206687288 is out of range for mov/mp4 format
Sep 25, 2018 12:31:18.740 [10428] ERROR - [Transcoder] [mp4 @ 127db180] Application provided duration: -16 / timestamp: 207889448 is out of range for mov/mp4 format
Sep 25, 2018 12:31:18.865 [0608] ERROR - [Transcoder] [mp4 @ 0410bfc0] Application provided duration: -16 / timestamp: 206736440 is out of range for mov/mp4 format
Sep 25, 2018 12:31:19.100 [0608] ERROR - [Transcoder] [mp4 @ 0410bfc0] Application provided duration: -16 / timestamp: 206783560 is out of range for mov/mp4 format
Sep 25, 2018 12:31:19.396 [2660] ERROR - [Transcoder] [mp4 @ 127db180] Application provided duration: -16 / timestamp: 207985736 is out of range for mov/mp4 format
Sep 25, 2018 12:31:19.396 [1068] ERROR - [Transcoder] [mp4 @ 0410bfc0] Application provided duration: -16 / timestamp: 206832712 is out of range for mov/mp4 format
Sep 25, 2018 12:31:19.631 [1468] ERROR - [Transcoder] [mp4 @ 0410bfc0] Application provided duration: -16 / timestamp: 206879800 is out of range for mov/mp4 format
Sep 25, 2018 12:31:19.646 [7156] ERROR - [Transcoder] [mp4 @ 127db180] Application provided duration: -16 / timestamp: 208030760 is out of range for mov/mp4 format
Sep 25, 2018 12:31:19.928 [7156] ERROR - [Transcoder] [mp4 @ 0410bfc0] Application provided duration: -16 / timestamp: 206928952 is out of range for mov/mp4 format
Sep 25, 2018 12:31:19.943 [4868] ERROR - [Transcoder] [mp4 @ 127db180] Application provided duration: -16 / timestamp: 208079912 is out of range for mov/mp4 format
Sep 25, 2018 12:31:20.427 [2660] ERROR - [Transcoder] [mp4 @ 0410bfc0] Application provided duration: -16 / timestamp: 207023176 is out of range for mov/mp4 format
Sep 25, 2018 12:31:20.662 [10428] ERROR - [Transcoder] [mp4 @ 0410bfc0] Application provided duration: -16 / timestamp: 207072328 is out of range for mov/mp4 format
Sep 25, 2018 12:31:20.990 [0608] ERROR - [Transcoder] [mp4 @ 0410bfc0] Application provided duration: -16 / timestamp: 207119432 is out of range for mov/mp4 format
Sep 25, 2018 12:31:21.334 [12256] ERROR - [Transcoder] [mp4 @ 0410bfc0] Application provided duration: -16 / timestamp: 207168584 is out of range for mov/mp4 format
Sep 25, 2018 12:31:21.912 [0608] ERROR - [Transcoder] [mp4 @ 08848a40] Application provided duration: -16 / timestamp: 95710264 is out of range for mov/mp4 format
Blockquote
