Server Version#: 1.40.0.7998
Player Version#: 8.31
There is no option for modifying subtitle offsets. See screenshot.
Works only with SRT subtitles in the same folder as the media file.
Those say “OpenSubtitles” so if they the ones from search, those should work with offsets. but afaik it needs to be direct streaming the subs. if they are being transcoded into the video it cannot however so check the dashboard
What model iOS device is that on? You seem to be missing Lock to Landscape and subtitle vertical position settings as well.
I tried to reproduce on my device but cannot.
