Server Version#: 1.19.3.2843
I’ve recently had to recreate and rescan my movies with slightly different filenames into an existing library (so as to not lose all the metadata-curating I’ve done). Along with that, I started adding local extras for several movies.
When it initially scans, it puts it as a separate library entry until the metadata match, at which point it gets merged into the existing entry, however the local extras don’t get merged with it. Rescanning doesn’t make them appear.
I’ve found that simply renaming one of the files after the metadata match causes it to treat the entire directory as new and properly show the extras. A rescan isn’t required.
Thanks!
