Local Extras not being recognized
Server Version#: 1.19.4.2935
Player Version#: 4.37.2
I have several extras for a movie. They follow Plex’s specified naming convention for subdirectories as shown at https://support.plex.tv/articles/local-files-for-trailers-and-extras/, but they are not being recognized. I added the extras to the appropriate folders, re-scanned the library files, refreshed the library metadata, and refreshed the metadata for the specific movie, and the extras still do not show up on the movie’s page.
/Movies
  /Movie_Name
    /Featurettes
      extra1.mp4
      extra2.mp4
    /Trailers
      extra3.mp4
    /Interviews
      extra4.mp4
    Movie_Name - 4K.mkv
    Movie_Name - 4K.eng.srt
    Movie_Name - 1080p.mkv
    Movie_Name - 1080p.eng.srt
Do you have local media extras enabled as a source for the agent used on that library?
Under Settings --> Agents I have Local Media Assets enabled.
Is that the setting that you are referring to?
That’s the one… well… there’s actually quite a lot of them :wink:
When you pick Movies, this will let you configure 3 default agents (+whatever custom agents you added to your setup):
  • Personal Media
  • Plex Movie
  • The Movie Database
Depending on what agent you’re using in your movie library… is Local Media Assets checked for that agent? (default movie library agent is Plex Movie)
Across all three, Personal Media, Plex Movie, and The Movie Database, I have Local Media Assets enabled.
Could you upload your logs here and share what movie/extras to look for?
Checked your logs
I take it you added those extras after Plex had catalogued the movie and have since only tried to scan the library for updates.
Give it a try and click Refresh Metadata from the context menu of that movie… from what I understand, the local media assets are not so much processed by the scanner but as a source to the agent that handles the metadata of your media.
You are correct. The extras were added quite a while after the movie itself.
I have refreshed the metadata for the entire library as well as for that specific movie and the extras still aren’t showing up. I also tried completely deleting the movie from the library and then re-adding, but the same problem persists.
You’ll have to wait for server version 1.19.6
This will bring a fix for this bug
Local assets were being ignored in folders with multiple versions of the same media.
