Server Version#:1.25.8.5663
Player Version#:8.31.0
I have created collections through PMS.
I noticed if I mark the item as watched/played through Plex for Android TV, it will remove the collection tag(s) that were already set.
Was the collection built from a filter, which included the playback status?
I added all my items either through the search > add to, or i added them through the Library view, but i can’t say for certain if a filter was set when I added them from the Library view page.
I am going to try and enable the lock icon for each item, see if that prevents the collection from being removed after watching.
That’s a problem. It means that the contents of the collection field can change at any time.
Are your media stored inside the server? If not, I urge you to disable this setting. Otherwise you may experience suddenly changing metadata again and again.
Thank you for your help!
Yes, the media is locally stored.
I gave a quick test of a locked collection and marking as watched/unwatched did not remove the collection tag.
