When you start a movie watch it for a bit to the point where it can resume. Then hit back. The resume button doesn’t update…
If you leave the movie… then re-enter it… It then updates.
Small annoying bug that I hope is fixed before this is released live. Just seems like the movie page for the movie you are watching isn’t updating after you hit stop on a movie.
Didn’t do this on previous version.
We’ve recognised the issue and we’ll work on a fix. Thanks for reporting.
Just released a beta that should fix your problem. Make sure you try it out when you receive the update!
Thank you… can confirm it did… Keep up the good work. Good to see devs responding and fixing bugs in betas.
Can’t wait too see the changes on the Android TV side… I hope they are good and fix the issues that plague it… esp the single season for TV show errors.
Still happening in Plex for Android 7.17.0.
