[BUG] Plexamp adds entire library to existing playlist when using filters
Description:
When filtering your library and trying to add the results to an existing playlist, the entire library is added to the playlist instead of the filtered list. This issue doesn’t happen when adding to a new playlist. This only impacts Plexamp and does not occur on the regular Plex desktop and web apps.
Server Version#: 1.41.0.8992
Player Version#: Both Windows and Android Plexamp 4.11.1
Steps to reproduce:
  1. Create a playlist
  2. Add any track to the playlist
  3. Navigate to Library and choose any item in the list such as artists or albums
  4. Click the filter button and add some filters
  5. Click the add to playlist button and select your existing playlist
Expected:
The filtered selection should be added to the playlist.
Actual:
The entire music library is added to the playlist.
Logs:
android-496001393568642.zip (306.6 KB)
Thanks for the report, fixed in the next release.
