[Feature Request] Add to Playlist and Delete Playlist
I love the new feature on Plexamp that displays the icons to shuffle, and create playlist on top of the view. One thing I would love to see is the ability to create a Playlist, then go back and add more content to that playlist directly within Plexamp instead of going to my dashboard on my laptop in Windows. Also, the ability to delete that playlist directly in Plexamp when I decide I no longer want to use it.
Add to playlist is part of the popup context menus.
Delete from playlist/delete playlist has been requested.
I am not seeing the ability to add to an existing playlist. For example, I have a “Metal” playlist and I cannot add content to it without going into my Windows dashboard.
oh mmm yeah you can’t add to FROM the playlist, but you can add from everything else, see below. if you wanting to add FROM the playlist, then you are right that would be a new request…
image image
Ok, thanks for the reply! I just really want the ability to add multiple Genres, moods, or styles into combined Playlists and then have the ability to delete them when no longer needed. Since the regular Plex app has the filter/check box combination it is easier to do it there but I typically only use Plexamp as a dedicated music player.
oh… well you can filter now with plexamp 3.4… so you can do genre, style, and mood into one.
are you referring to something else?
This is the one, very simple, but USEFUL feature the standard Plex app has over Plexamp that there is no way to recreate without going back and forth between your web dashboard and Plexamp over and over again:
Oh, man! How did you get there?? Maybe I don’t have the latest version.
it’s the filter icon, the lines that look like a beacon… check out my how to: search/look for filters
[How To] Plexamp 3.0 - Testing / Plex Labs - Plex Forum
Wow, that made my day! Thank you!!
Well, the bad news is I still cannot accomplish what I want. Because if I want to narrow down to two genres… For example “Alternative and Grunge” using the Filter, by the time I use the filter on the first Genre, the other one is excluded. Unless there is another way to do this??
Ok, I already figured it out!!
