Plexamp pulls in all playlists from multiple libraries
Server Version#: v4.141.0
Player Version#: Plexamp v4.11.2
I have two libraries setup that I am accessing using plexamp. Library Alpha has multiple playlists. Library Beta has one.
On Plex Web and the Plex app, the playlists show properly in their respective libraries.
However in Plexamp, the playlists are merged and seen when accessing either library.
How do I prevent this?
typically playlists aren’t specific to a library, as you can add tracks from multiple libraries to a single playlist. i’m actually not sure what the web app is doing to segregate them like that, would need to check.
Thanks for the response! Not knowing how you have it implemented, would it be difficult to add an option in Plexamp that is something like “Only show playlists from selected library”? The two libraries I have are his and hers and it would just be a bit nicer to have them separated.
I’ve changed the behavior to match what the Plex app does (or more closely, at least).
Thank you, I’ll keep an eye out for an update.
An update came out and the behavior was fixed. Then a two days later another update came out and the behavior reverted. So, it worked for a day or two.
4.11.3 works
4.11.4 does not
There is now a preference for it, if you read the release notes :sweat_smile: So everyone can have the behavior they prefer.
