[Bug] Plexamp Desktop mode seekbar
Hi! Currently messing around with the 4.50.20-beta 18 build for Windows x64 and loving Desktop mode (thank you!!!). I’m noticing though in the new Desktop view, the seekbar at the bottom for a currently playing track is working correctly but when I blow up the Now Playing screen to full screen, the seekbar doesn’t move and is stuck at the end of the song (the song itself still plays, just the visual of the seekbar isn’t correct)
At the bottom of the window (seekbar moves as expected):
Full screen (seekbar doesn’t move and just stays at the end of the song):
Thanks, the screenshot gave it away. The full player was borrowing the player bar’s progress, and on a wide window that bar is a lot longer, so a third of the way in it looks finished. Fixed for the next beta.
Fixed in 4.50.20-beta.19, which is out on the desktop beta channel now.
Looks good! Thank you!
