[Bug] Plexamp ignores Repeat Once setting
Hello.
As title says: Player ignores “Repeat once” setting.
I like to just shuffle my entire library for listening normally, but when I need to focus I sometimes just want a single song on repeat, often for hours. Sadly repeat in Plexamp is pretty broken:
Shuffle play, switch to repeat once: Repeat gets switched off, next song starts.
Album play, switch to repeat once: Repeat gets switched off, next song starts.
Clear play queue switch to repeat all: App exits.
Workaround:
The only thing that works is to put the same song in the otherwise empty queue TWICE and switch on Repeat ALL.
HOWEVER, if set to Repeat ONCE, it gets switched off again.
Version: Plexamp v4.12.0
Phone: Android 13
There is a bug in the current release which will be fixed in the next one, which affects Opus tracks which are set to repeat.
If you are having this issue with tracks which aren’t Opus, please post Plexamp logs and we will have a look!
Thanks for the reply.
You left me a bit unsure, as after testing the last tracks I remember noticing this behaviour at again, they did indeed show Opus as format. But after checking the files on the server, those were FLAC instead.
I have since caught the app two more times, where it showed FLAC files as Opus.
At least the “repeat once” behavior is working now regardless. So I assume this has been fixed since, as I am now on v4.12.2.
About it showing the wrong file format, you have to take my word on it, because I have not been able to reproduce it on purpose.
the Opus/Flac thing is because you’re playing a cached transcode instead of playing the original.
