BUG - Plexamp scaling
Server Version#: 1.40.0.7998 (ubuntu)
Player Version#: 4.10.1 (plexamp windows 10)
I am running Plexamp on a LG Gram laptop with windows 10. I am using dual monitors: laptop monitor 2560x1600 resolution scaled +150%
external monitor 1920x1080 resolution scaled 100%
My main display is the laptop monitor (it is scaled +150%) but I normally keep plexamp on the secondary monitor (not scaled).
When plexamp launches and opens on the secondary monitor the window is scaled down much smaller than it was when it was closed (looks to be about 2/3 the size). If you immediately close it and re-open, it will keep getting smaller each time.
If I move plexamp to the main display and close/re-open the window size stays the same.
I have a similar problem on my dual monitor setup. My main monitor is 3440x1440@100% scale, my second monitor is 1080p@125%. Whenever I have plexamp on the second monitor it gets scaled up after a restart and shifts to the right.
I have the same issue; plexamp window gets larger each time I open it on the secondary monitor. Main is 3440x1440, scaling 100% and secondary is 3840x2160, scaling 125%. It seems that this is an issue due to one monitor being scaled and the other not.
