I have a movie with a TrueHD audio track. Direct Stream / Direct Play works just fine to play the movie, but if I turn those off or if I attempt to play the movie on a device that doesn’t support TrueHD (i.e. Plex would need to transcode the audio), the player just hangs. Doesn’t matter what player it is: Roku, Web, Plex Media Player, Plex for Android. They all do the same thing. I think the Roku eventually kicks back an error playing the file, but that’s it. Monitoring it with PlexPy/Tautulli, I never see the stream or transcode start. However, if I change the audio track to the AC3 stream, the movie immediately begins to play.
Am I correct in understanding that Plex Media Server for Windows cannot read (for transcoding) TrueHD audio streams and also doesn’t handle the fact that it can’t so it just locks up?
Is this an open bug somewhere? I would understand some audio streams not being supported, but I don’t understand the lock up. PMS should return an error to the player like “Can’t transcode unsupported audio stream” or something like that. Or better yet, change to a different audio stream of the same language and channels, if possible (or at least the same language).
Environment
Plex Media Server v1.12.0.4829
Windows Server 2012 R2
I can confirm the same behaviour on my PMS.
Playing a Movie with TrueHD audio in Transcode mode results in a never ending spinning wheel. Selecting the same movie but with AC3 5.1 works fine.
I see these lines in the log while the circle is spinning:
From Plex Media Server.1.log:
Mar 13, 2018 08:29:38.002 [1700] ERROR - [Transcoder] [truehd_eae @ 0249a180] EAE timeout! EAE not running, or wrong folder? Could not read ‘\?\C:\Users\SVC_PlexMediaSvr\AppData\Local\Plex Media Server\Cache\Transcode\Sessions\EasyAudioEncoder\Convert to WAV (to 8ch or less)\9zacs1y12obqcbkdldleeq6m_4072-1-0.wav’
Mar 13, 2018 08:29:38.017 [6328] ERROR - [Transcoder] [truehd_eae @ 0249a180] error reading output
Mar 13, 2018 08:29:38.017 [6532] ERROR - [Transcoder] Error while decoding stream #0:1: I/O error
Same problem here. Tried deleting Codecs folder which helped before (several versions, more than a year ago) but not now. I’m on Ubuntu, doesn’t seem to be platform specific.
I have this same issue and encounter the " Conversion failed. A required codec could not be found or failed to install." error when trying to playback any files using the TrueHD sound file that seems corrected when selecting another Sound file for the video. Running on an Unraid Server. logs attached.
I’m running plex on a 3rd gen i5 desktop. I used to be able to optimize my 4k movies so I can play them on my apple TV but they fail now. I noticed this started when the 4k movies I was getting had TrueHD audio. I just tried the above steps on mine and going to see if this works. If it does it seems like a temp solution. Anyway we can get a plex member on this thread so they can find a fix?
