Bug?: Pressing on a song brings up context menu
Server Version#: 1.21.0.3744
Player Version#: 4.3.0
Expected behavior: pressing on a song in a playlist/album/etc. plays the song immediately
Current behavior: Plexamp shows the context menu, where you then must press play song
Is this happening to anyone else? It doesn’t seem like the norm to show an options menu when I want to just play the song. I see three dots to the right for this action, but currently it doesn’t matter where I touch, it always brings up that menu.
There’s a setting for that. Under advanced, called “1-tap track play”. Enable it and it will always a play the song.
Thank you! Why this isn’t the default seems odd since there are the three dots to the side.
