Bug Report: Blank Plexamp Context Menus With White Theme
Hi, I’m running Plexamp v 3.9.0 on Android. For a number of days now, when I try to view a context menu (e.g., long press an album or hit the 3 dots next to a playlist) the menu that appears is solid black and I can’t see any of the text options. Ironically, they are still there and if I guess correctly and touch the right spot it will perform the action (e.g., shuffle playlist, download, etc).
I tried to troubleshoot a bit and ended up poking around the settings, where I noticed that if I change to Dark or Black theme (I was using White), the menus are fine (dark menu with white text). But with White theme, it appears I’m getting a solid black menu with black text. I also tried Light theme, which has very faint text (hard to see against similar background).
Not sure if anyone else is having this issue, but wanted to let you guys know.
Fixed in v3.9.1, thanks!
