Plex DLNA Server.log (79.6 KB) Plex Media Server.log (193.4 KB)
Server Version#: 1.13.9.5456
Player Version#: DLNA / WDTV Live
UPDATE - ALL DLNA Updates seem to be broken!
DLNA communication back to Server may be broken in 1.13.9.5456. I was previously on 1.13.7 something and it worked fine.
Prior to update WDTV would update Now Playing, On Deck, Recently Viewed Shows, Recently Viewed Episodes - now no updates at all
Works fine on Plex Web and Plex Media Player on Mac, so may be a DLNA issue
When I make updates on Web or Player, the WDTV can query fine (shows current info) but does not update server
Same issue with Movies
Short log attached - points below related to DLNA timeline reporting. Longer logs can be provided if needed.
DLNA Server Log - started a TV show at line 175. on Line 285 a timeline request is sent and returns a 404 error!
Plex Media Server Log - same show starts at line 716. Timeline request done on line 766. between these points there are several DEBUG stating “Failed to stream media, client probably disconnected …” not sure if that means anything.
FYI - downgraded to 1.13.7-5369 and it works fine again! Will stay on this until there’s a fix
Plex team used to be pretty good at scanning issues. I reclassified mine under Plex Media Server group (had it under players for some reason). Maybe that will get their attention. Not sure what else to do
I haven’t upgraded yet. But in the past, the timeline information was never sent back to the WDTV only from the WDTV to Plex. In Plex, the activity page showed progress and the WDTV managed its own progress (as long as I didn’t turn the WDTV off, it would remember where I was for any given show / movie. If i turned it off and back on, Plex would still show progress in the Activity window, but i’d lose it on WDTV.
Is that different that what you are seeing now?
