Bug report for SKIP INTRO analysis
Server Version#: 1.19.4.2935-79e214ead (Netgear R9000)
Player Version#: Version 4.37.2 (web)
Plex Media Server Logs_2020-07-10_18-23-37.zip (39.5 KB)
Season 3 sample (full episode 1).
Repettive error:
Jul 10, 2020 18:22:24.000 [0xacda1460] ERROR - [Transcoder] [eac3_eae @ 0x1fcf10] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/mnt/sda1/pms-4d5cdcf6-a218-4569-aa3c-7f78ad3b731d/EasyAudioEncoder/Convert to WAV (to 8ch or less)/40c12caa-0afb-414e-9fc5-2e3a6fd06523_5698-0-48.wav'
Jul 10, 2020 18:22:24.001 [0xabefb460] ERROR - [Transcoder] [eac3_eae @ 0x1fcf10] error reading output
Jul 10, 2020 18:22:24.005 [0xb2390460] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Jul 10, 2020 18:22:27.002 [0xaf1fc460] ERROR - [Transcoder] [eac3_eae @ 0x1fcf10] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/mnt/sda1/pms-4d5cdcf6-a218-4569-aa3c-7f78ad3b731d/EasyAudioEncoder/Convert to WAV (to 8ch or less)/40c12caa-0afb-414e-9fc5-2e3a6fd06523_5698-0-49.wav'
Jul 10, 2020 18:22:27.004 [0xb2390460] ERROR - [Transcoder] [eac3_eae @ 0x1fcf10] error reading output
Jul 10, 2020 18:22:27.005 [0xacda1460] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Hi.
I’ve tryed to Analyze season 3 from Dark (Dark.S03.1080p.NF.WEB-DL.DDP5.1.x264-NTG), but looking on dashboard activity and console logs I’ve seen most errors and the analysis never ended, the process
takes for ever.
Other TV Series like Homeland (Homeland.S03.1080p.Bluray.DD5.1.x264-EbP) or Punisher (Marvels.The.Punisher.S01.1080p.NF.WEB-DL.DD5.1.x264-NTb) has been succesuful analyzed and the SKIP INTRO works perfect.
You mount your sda inside /tmp? Sounds weird.
“flagged as inappropriate” ok …
I was pointing out a possible reason for the input/output error
a) the transcoder should not default to /tmp (anymore, since the fix iirc)
b) tmp is often space limited, which will result in i/o errors, maybe gets wiped when space is full, depending on the distro
c) tmp is not a default mountpoint for anything, so something has been edited somewhere, maybe incorrectly
Do these files transcode ok during playback ?
The EasyAudioEncoder is failing just after launch
Didn’t mount anything. That’s all Netgear’s work on R9000 router.
Hi @sa2000.
Can’t test it with transcoding because the Netgear R9000 it’s weak in terms of performance and cannot handle a file that big for transcoding. I always Direct Play all files so I have no problems that way.
On the Netgear R9000, the binaries go here
/tmp/plexmediaserver/xxxxx version number of PMS xxxxx
e.g.
/tmp/plexmediaserver/1.19.4.2935-79e214ead/
and the data area goes here
/tmp/mnt/sda1/Library/Application Support/Plex Media Server/
The EasyAudioEncoder binary gets downloaded into the data area - so will need to establish if that mount has EXEC attribute and no NOEXEC
I’ve tested again, this time with transcoding scenario, and the console output seems to be the same. The web player can’t play. Looking on console or logs, there are same erros.
Same erros like the ones when I try to analyze the season with Skip Intro creation.
Jul 11, 2020 13:47:11.351 [0xb3635460] DEBUG - Auth: authenticated user 1 as Claudiu
Jul 11, 2020 13:47:11.351 [0xaf823460] DEBUG - Request: [192.168.1.2:1855 (Subnet)] GET /activities (11 live) TLS GZIP Signed-in Token (Claudiu )
Jul 11, 2020 13:47:11.352 [0xb3923460] DEBUG - Completed: [192.168.1.2:1855] 200 GET /activities (11 live) TLS GZIP 0ms 429 bytes (pipelined: 8)
Jul 11, 2020 13:47:13.845 [0xb3635460] DEBUG - Completed: [192.168.1.2:1692] 200 GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (11 live) TLS GZIP 20000ms 5 bytes (pipelined: 22)
Jul 11, 2020 13:47:13.869 [0xb3635460] DEBUG - Auth: authenticated user 1 as Claudiu
Jul 11, 2020 13:47:13.869 [0xaf823460] DEBUG - Request: [192.168.1.2:1692 (Subnet)] GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (11 live) TLS GZIP Signed-in Token (Claudiu )
Jul 11, 2020 13:47:13.869 [0xaf823460] DEBUG - Content-Length is -1 (of total: -1).
Jul 11, 2020 13:47:14.000 [0xaf823460] ERROR - [Transcoder] [eac3_eae @ 0x28c8f0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/mnt/sda1/pms-37941fcd-291c-4fea-9fec-80cbde7d0624/EasyAudioEncoder/Convert to WAV (to 8ch or less)/dwsarmvjznnqz884tucxduds_15033-0-1.wav'
Jul 11, 2020 13:47:14.274 [0xaf823460] ERROR - [Transcoder] [eac3_eae @ 0x28c8f0] error reading output
Jul 11, 2020 13:47:14.277 [0xaf823460] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Jul 11, 2020 13:47:17.000 [0xaf823460] ERROR - [Transcoder] [eac3_eae @ 0x28c8f0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/mnt/sda1/pms-37941fcd-291c-4fea-9fec-80cbde7d0624/EasyAudioEncoder/Convert to WAV (to 8ch or less)/dwsarmvjznnqz884tucxduds_15033-0-2.wav'
Jul 11, 2020 13:47:17.048 [0xaf823460] ERROR - [Transcoder] [eac3_eae @ 0x28c8f0] error reading output
Jul 11, 2020 13:47:17.049 [0xaf823460] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Jul 11, 2020 13:47:20.000 [0xaf823460] ERROR - [Transcoder] [eac3_eae @ 0x28c8f0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/mnt/sda1/pms-37941fcd-291c-4fea-9fec-80cbde7d0624/EasyAudioEncoder/Convert to WAV (to 8ch or less)/dwsarmvjznnqz884tucxduds_15033-0-3.wav'
Jul 11, 2020 13:47:20.007 [0xaf823460] ERROR - [Transcoder] [eac3_eae @ 0x28c8f0] error reading output
Jul 11, 2020 13:47:20.009 [0xaf823460] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Jul 11, 2020 13:47:20.912 [0xb3635460] DEBUG - Auth: authenticated user 1 as Claudiu
Jul 11, 2020 13:47:20.912 [0xaf823460] DEBUG - Request: [192.168.1.2:1855 (Subnet)] GET /:/timeline?ratingKey=3&key=%2Flibrary%2Fmetadata%2F3&playbackTime=0&playQueueItemID=9&state=paused&hasMDE=1&time=0&duration=3726000 (11 live) TLS GZIP Signed-in Token (Claudiu )
Jul 11, 2020 13:47:20.914 [0xaf823460] DEBUG - Client [jt7xpp5czzpzns9js20qcrkv] reporting timeline state paused, progress of 0/3726000ms for guid=, playbackTime=0ms ratingKey=3 url=, key=/library/metadata/3, containerKey=, metadataId=3, source=
Jul 11, 2020 13:47:20.931 [0xaf823460] DEBUG - [Now] User is Claudiu  (ID: 1)
Jul 11, 2020 13:47:20.935 [0xaf823460] DEBUG - [Now] Device is Chrome (Chrome).
Jul 11, 2020 13:47:20.935 [0xaf823460] DEBUG - [Now] Profile is Web
Jul 11, 2020 13:47:20.935 [0xaf823460] DEBUG - [Now] Updated play state for /library/metadata/3.
Jul 11, 2020 13:47:20.936 [0xaf823460] DEBUG - Statistics: (mtlcp2vc3nqkfinje8oj94nb) Reporting active playback in state 1 of type 4 (scrobble: 0) for account 1
Jul 11, 2020 13:47:20.951 [0xb3635460] DEBUG - Completed: [192.168.1.2:1855] 200 GET /:/timeline?ratingKey=3&key=%2Flibrary%2Fmetadata%2F3&playbackTime=0&playQueueItemID=9&state=paused&hasMDE=1&time=0&duration=3726000 (11 live) TLS GZIP 38ms 774 bytes (pipelined: 9)
Jul 11, 2020 13:47:23.000 [0xaf823460] ERROR - [Transcoder] [eac3_eae @ 0x28c8f0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/mnt/sda1/pms-37941fcd-291c-4fea-9fec-80cbde7d0624/EasyAudioEncoder/Convert to WAV (to 8ch or less)/dwsarmvjznnqz884tucxduds_15033-0-4.wav'
Jul 11, 2020 13:47:23.001 [0xaf823460] ERROR - [Transcoder] [eac3_eae @ 0x28c8f0] error reading output
Jul 11, 2020 13:47:23.002 [0xaf823460] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Anyway, I’ve installed Plex Server on my Windows Machine, and tried the same files to play and analyze, and everything works fine, no errors.
I guess this is a problem with Netgear R9000 Plex Server - 1.19.4.2935-79e214ead
My guess at the moment is that mount for this does not allow execution of binaries - only a guess at this stage
The device I understand is capable of Direct Streaming and Transcoding to 480p
@sa2000
Checked all important locations for permissions:
/mnt/sda1
/mnt/sda1/pms-37941fcd-291c-4fea-9fec-80cbde7d0624 - the one that it’s active
All of them got rwx on all users. I even chmod-ed them again to be sure, even on child objects (for the sake of test).
I suspect there could be a problem with the codec library for this distribution.
There aren’t any problems with permissions.
Yes. The router can transcode some files. And the transcoding works sometimes, when EasyAudioEncoder isn’t needed. Please bear that in mind.
thanks - could you do list directory for this and all the lower level directories and contents listing all files with sizes / dates etc
/tmp/mnt/sda1/Library/Application Support/Plex Media Server/Codecs/
-rw-r--r--    1 root     root            6 Jul 11 14:35 -pid
---------x    1 root     root            3 Jul 11 14:36 04_92_26_c2_a7_22Mozilla_5_0__Windows_NT_10_0__Win64__x64__AppleWebKit_537_36__KHTML__like_Gecko__Chrome_83_0_4103_116_Safari_537_36
-rw-r--r--    1 root     root           18 Apr 24 19:09 11ad_mac
---------x    1 root     root            1 Jul 11 14:35 313137947683
---------x    1 root     root            1 Jul 11 14:34 4654142312764642
---------x    1 root     root            1 Jul 11 14:27 605620272956720
---------x    1 root     root            1 Jul 11 14:26 679877350
---------x    1 root     root            1 Jul 11 14:26 760861957769
---------x    1 root     root            1 Jul 11 14:37 9748639960
---------x    1 root     root            1 Jul 11 14:27 9909270927874351
-rw-r--r--    1 root     root            2 Jul 11 14:26 ABC_language_reboot
-rws--S--T    1 root     root          132 Jul 11 14:27 AUTH_login_browser
---------x    1 root     root            3 Jul 11 14:27 AUTH_login_dev
-------r--    1 root     root            0 Jul 11 14:36 AUTH_login_error
---xr-s--T    1 root     root           11 Jul 11 14:27 AUTH_login_ip
---------x    1 root     root           17 Jul 11 14:27 AUTH_login_mac
--w-------    1 root     root            3 Jul 11 14:36 AUTH_login_time
-rw-r--r--    1 root     root            4 Jul 11 14:27 AUTH_no_need_auth
-rw-r--r--    1 root     root            4 Jul 11 14:27 AUTH_nullpass
-rw-r--r--    1 root     root           10 Jul 11 14:32 LAN0_status
-rw-r--r--    1 root     root            3 Jul 11 14:32 LAN0_uptime
-rw-r--r--    1 root     root            9 Apr 24 19:09 LAN1_status
-rw-r--r--    1 root     root            9 Apr 24 19:09 LAN2_status
-rw-r--r--    1 root     root            9 Apr 24 19:09 LAN3_status
-rw-r--r--    1 root     root            9 Apr 24 19:09 LAN4_status
-rw-r--r--    1 root     root            9 Apr 24 19:09 LAN5_status
-rw-r--r--    1 root     root            4 Jul 11 14:38 POT_netconn
-rw-r--r--    1 root     root            9 Jul 11 14:38 SFP_status
-rw-r--r--    1 root     root           14 Jul 11 14:37 Seria_Number
-rw-r--r--    1 root     root            0 Jul 11 14:32 StaticRouteList
-rw-r--r--    1 root     root           10 Apr 24 19:09 WAN_status
-rw-r--r--    1 root     root            2 Apr 24 19:09 WAN_uptime
-rw-r--r--    1 root     root            3 Jul 11 14:32 WLAN_2G_status
-rw-r--r--    1 root     root            3 Jul 11 14:32 WLAN_5G_status
-rw-r--r--    1 root     root            3 Jul 11 14:32 WLAN_60G_status
-rw-r--r--    1 root     root            7 Jul 11 14:32 WLAN_uptime
-rw-r--r--    1 root     root            7 Jul 11 14:32 WLAN_uptime_5G
-rw-r--r--    1 root     root            7 Jul 11 14:32 WLAN_uptime_60G
-rw-r--r--    1 root     root          133 Jul 11 14:26 access_device_list
---------T    1 root     root          174 Jul 11 14:27 auth_token_04:92:26:c2:a7:22
-rw-r--r--    1 root     root            4 Jul 11 14:26 auto_ctlfile
-rw-r--r--    1 root     root          489 Jul 11 14:26 auto_fw_upgrade_log
-rwSr-xr-T    1 root     root            9 Jul 11 14:26 auto_version
drwxr-xr-x    3 root     root           60 Jul 11 14:26 avahi
-rw-r--r--    1 root     root           18 Apr 24 19:09 bluetooth_mac
-rw-r--r--    1 root     root           28 Apr 24 19:09 board_hw_id
-rw-r--r--    1 root     root            6 Jul 11 14:37 board_model_id
drwxr-xr-x    3 root     root           60 Jul 11 14:26 cache
drwxr-xr-x    2 root     root          120 Jul 11 14:27 config
-rw-r--r--    1 root     root      1179648 Apr 24 19:09 config_data
-rw-r--r--    1 root     root       262144 Jul 11 14:26 crash_log
-rw-r--r--    1 root     root          317 Jul 11 14:26 curl_error
-rw-r--r--    1 root     root            2 Jul 11 14:33 debug-usb
-rw-r--r--    1 root     root            8 Jul 11 14:37 debug_11ad_temperature
-rw-r--r--    1 root     root            4 Jul 11 14:37 debug_2g_temperature
-rw-r--r--    1 root     root            4 Jul 11 14:37 debug_5g_temperature
-rw-r--r--    1 root     root            8 Jul 11 14:37 debug_antenna_temperature
-rw-r--r--    1 root     root           52 Jul 11 14:33 debug_cpu
-rw-r--r--    1 root     root            3 Jul 11 14:37 debug_cpu_temperature
-rw-r--r--    1 root     root           12 Jul 11 14:33 debug_flash
-rw-r--r--    1 root     root           13 Jul 11 14:33 debug_mem
-rw-r--r--    1 root     root           10 Jul 11 14:33 debug_session
-rw-r--r--    1 root     root           13 Jul 11 14:33 debug_wlan
-rw-r--r--    1 root     root           14 Jul 11 14:37 default_gw
-rw-r--r--    1 root     root            6 Jul 11 14:32 dhcp_name.conf
-rw-r--r--    1 root     root            0 Jul 11 14:28 dhcpc_resolv.conf
-rw-r--r--    1 root     root           19 Jul 11 14:36 dhcpd_hostlist
-rw-r--r--    1 root     root            5 Jul 11 14:35 disk_format
-rw-r--r--    1 root     root            4 Jul 11 14:34 disk_loop_partition
-rw-r--r--    1 root     root            4 Jul 11 14:35 disk_loop_pt
-rw-r--r--    1 root     root            4 Jul 11 14:34 disk_loop_tb
-rw-r--r--    1 root     root          204 Jul 11 14:32 disk_scsi_info_dlna
-rw-r--r--    1 root     root            5 Jul 11 14:35 disk_special_format
----------    1 root     root            1 Jul 11 14:34 enable_telnet
drwxr-xr-x    4 root     root          120 Jul 11 14:32 etc
-rw-r--r--    1 root     root         3597 Jul 11 14:26 fileinfo.txt
-rw-r--r--    1 root     root           56 Jul 11 14:32 find_disk_abcxzy
-rw-r--r--    1 root     root           56 Jul 11 14:32 find_disk_abcxzy_backup
-rw-r--r--    1 root     root            2 Jul 11 14:34 firmware_region
-rwSr-xr-T    1 root     root            1 Jul 11 14:26 fw_check_status
-rw-r--r--    1 root     root            0 Apr 24 19:09 fw_lock_file
-rw-r--r--    1 root     root            6 Apr 24 19:09 hardware_version
-rw-r--r--    1 root     root           38 Jul 11 14:32 hosts
-rw-r--r--    1 root     root            0 Jul 11 14:28 ipv6_dns
-rw-r--r--    1 root     root          186 Jul 11 14:38 ipv6_ip_mac
-rw-r--r--    1 root     root         1374 Jul 11 14:37 irq_backup_file
----r-S---    1 root     root            1 Jul 11 14:36 is_login_04:92:26:c2:a7:22
drwxr-xr-x    4 root     root          320 Jul 11 14:35 js_cache
-rw-r--r--    1 root     root           18 Apr 24 19:09 lan_mac
-rw-r--r--    1 root     root      3670016 Jul 11 14:26 lang_file
-rw-r--r--    1 root     root            4 Jul 11 14:28 lang_status
-rw-r--r--    1 root     root            2 Jul 11 14:26 language_table_have_init
drwxr-xr-x    4 root     root           80 Jul 11 14:26 lib
drwxr-xr-x    5 root     root          380 Jul 11 14:34 lock
drwxr-xr-x    5 root     root          260 Jul 11 14:26 log
-rw-r--r--    1 root     root           18 Apr 24 19:09 mac_addr_2g
-rw-r--r--    1 root     root           18 Apr 24 19:09 mac_addr_5g
drwxr-xr-x    3 root     root           60 Apr 24 19:09 mnt
-rw-r--r--    1 root     root            6 Apr 24 19:09 module_name
-rw-r--r--    1 root     root            5 Jul 11 14:37 mount_disk_exists
drwxr-xr-x    2 1006     1002          120 Apr 20 09:06 multi_lang
-rw-r--r--    1 root     root            3 Jul 11 14:38 nas_stat
drwxr-xr-x    2 root     root           60 Jul 11 14:26 netatalk
drwxr-xr-x    2 root     root          100 Jul 11 14:27 netscan
-rw-r--r--    1 root     root          480 Jul 11 14:34 netwall-rules
-rw-r--r--    1 root     root           97 Apr 24 19:09 ntgrdns.conf
-rw-r--r--    1 root     root            4 Apr 24 19:09 ntgrpid
-rw-r--r--    1 root     root            0 Jul 11 14:28 ntp_updated
drwxr-xr-x    2 root     root          220 Jul 11 14:26 openvpn
drwxr-xr-x    2 root     root           40 Jan  1  1970 overlay
-rw-r--r--    1 root     root            9 Jul 11 14:37 partition_disk_exists
-rw-r--r--    1 root     root           13 Apr 24 19:09 passphrase-setted
-rw-r--r--    1 root     root          277 Jul 11 14:28 ping_adt_result
-rw-r--r--    1 root     root          364 Jul 11 14:37 ping_gw_result
-rw-r--r--    1 root     root            0 Jul 11 14:37 ping_gw_result_error
-rw-r--r--    1 root     root          395 Jul 11 14:37 ping_internet_result
-rw-r--r--    1 root     root            0 Jul 11 14:37 ping_internet_result_error
-rw-r--r--    1 root     root          454 Jul 11 14:28 ping_result
-rw-r--r--    1 root     root            0 Jul 11 14:28 ping_result_error
-rw-r--r--    1 root     root        16496 Jul 11 14:36 plex_binary_untar_info
-rw-r--r--    1 root     root            2 Jul 11 14:36 plex_check_result
-rw-r--r--    1 root     root          246 Jul 11 14:36 plex_check_tmp
-rw-r--r--    1 root     root         1999 Jul 11 14:36 plex_check_tmp2
-rw-r--r--    1 root     root           96 Jul 11 14:38 plex_curUSB_info
-rw-r--r--    1 root     root          225 Jul 11 14:37 plex_current_version
-rw-r--r--    1 root     root            2 Jul 11 14:36 plex_download_result
-rw-r--r--    1 root     root          225 Jul 11 14:36 plex_latest_version
dr----x--t    2 root     root           40 Jul 11 14:26 plex_net
-rw-r--r--    1 root     root            0 Jul 11 14:26 plex_ntp_updated
-rw-r--r--    1 root     root            8 Jul 11 14:36 plex_pcode
-rwsr-s--t    1 root     root            3 Jul 11 14:36 plex_reset_result
-rw-r--r--    1 root     root            2 Jul 11 14:37 plex_upgrade_result
drwxrwxrwx    4 1000     1000          544 Jul 11 14:37 plexmediaserver
-rw-r--r--    1 root     root    111089150 Jun 11 13:48 plexmediaserver-r9k-1.19.4.2935-79e214ead-armv7.tgz
-rw-r--r--    1 root     root            1 Jul 11 14:38 port_status
-rw-r--r--    1 root     root            4 Jul 11 14:27 pot_value
-rw-r--r--    1 root     root            2 Jul 11 14:26 printer1num
-rw-r--r--    1 root     root            2 Jul 11 14:26 printer3num
drwxr-xr-x    2 root     root           40 Jul 11 14:26 private
-rw-r--r--    1 root     root           62 Jul 11 14:36 pro_plexcode
-rw-r--r--    1 root     root            9 Apr 24 19:09 protime
-rw-r--r--    1 root     root           32 Jul 11 14:26 rae_md5
-rw-r--r--    1 root     root           18 Jul 11 14:26 rae_name
-rw-r--r--    1 root     root          449 Jul 11 14:26 rae_ping_result
-rw-r--r--    1 root     root            0 Jul 11 14:26 rae_ping_result_error
-rw-r--r--    1 root     root            7 Jul 11 14:26 rae_version
drwxr-xr-x    3 root     root           60 Jul 11 14:26 ramoops
-rw-r--r--    1 root     root           40 Jul 11 14:26 region
-rw-r--r--    1 root     root           57 Jul 11 14:28 resolv.conf
-rw-r--r--    1 root     root           25 Apr 24 19:09 resolv.conf.auto
----------    1 root     root            2 Jul 11 14:27 result_ap_autodetection
drwxr-xr-x    2 root     root          140 Jul 11 14:26 router-analytics
drwxr-xr-x    9 root     root          740 Jul 11 14:34 run
drwxr-xr-x    2 root     root          120 Jul 11 14:27 samba
-rw-r--r--    1 root     root            2 Apr 24 19:09 satadisknum
-rw-r--r--    1 root     root            8 Jul 11 14:35 sda_info_tmp
-rw-r--r--    1 root     root            2 Jul 11 14:29 set_txpower_lock
-rw-r--r--    1 root     root           18 Apr 24 19:09 sfp_mac
-rw-r--r--    1 root     root           14 Jul 11 14:37 sn-setted
-rw-r--r--    1 root     root           14 Jul 11 14:36 sn_plexcode
drwxr-xr-x    3 root     root           60 Jul 11 14:26 spool
-rw-r--r--    1 root     root         2726 Apr 24 19:09 ssdk_new.sh
-rw-r--r--    1 root     root           10 Apr 24 19:09 ssid-setted
-rw-r--r--    1 root     root           51 Jul 11 14:36 stainfo
drwxr-xr-x    2 root     root           80 Jul 11 14:26 state
-rw-r--r--    1 root     root            0 Apr 24 19:09 switch_haveset
-rw-r--r--    1 root     root           11 Jul 11 14:35 telnetip
-rw-r--r--    1 root     root           34 Jul 11 14:35 time_zone
-rw-r--r--    1 root     root            5 Jul 11 14:32 tmp_device_name_xyz
drwxr-xr-x    2 root     root          200 Jul 11 14:26 traffic_meter
-rw-r--r--    1 root     root            0 Jul 11 14:32 udhcpc_added_routes
-rw-r--r--    1 root     root            0 Jul 11 14:28 udhcpc_classless_static_route
-rw-r--r--    1 root     root            0 Jul 11 14:28 udhcpc_microsoft_classless_static_route
-rw-r--r--    1 root     root            0 Jul 11 14:28 udhcpc_static_route
-rw-r--r--    1 root     root          230 Jul 11 14:32 udhcpd.conf
-rw-r--r--    1 root     root            0 Apr 24 19:09 udhcpd.leases
----------    1 root     root            5 Jul 11 14:26 upgrade_method
-rw-r--r--    1 root     root           92 Jul 11 14:32 upnp_pmlist
-rw-r--r--    1 root     root            2 Apr 24 19:09 usb3num
-rw-r--r--    1 root     root           66 Apr 24 19:09 usb_map_table
-rw-r--r--    1 root     root            4 Jul 11 14:38 usb_par
-rw-r--r--    1 root     root            2 Jul 11 14:26 usbdisknum
-rw-r--r--    1 root     root            8 Jul 11 14:34 vol_id
-rw-r--r--    1 root     root            8 Jul 11 14:34 vol_id_1
-rw-r--r--    1 root     root            8 Jul 11 14:35 vol_id_2
-rw-r--r--    1 root     root            5 Jul 11 14:34 vol_id_fs
-rw-r--r--    1 root     root           16 Jul 11 14:28 wan_aggre
-rw-r--r--    1 root     root           18 Apr 24 19:09 wan_mac
-rw-r--r--    1 root     root          444 Jul 11 14:37 wifi0_ath0_all_sta
-rw-r--r--    1 root     root          994 Jul 11 14:28 wifi0_ath0_mibinfo
-rw-r--r--    1 root     root            0 Jul 11 14:37 wifi1_ath1_all_sta
-rw-r--r--    1 root     root          994 Jul 11 14:28 wifi1_ath1_mibinfo
-rw-r--r--    1 root     root            5 Jul 11 14:26 wifi_ath0
-rw-r--r--    1 root     root            2 Jul 11 14:38 wifi_down
drwxr-xr-x    2 root     root           80 Jul 11 14:26 wifi_update
-rw-r--r--    1 root     root            0 Jul 11 14:26 wifi_wlan0
drwxr-xr-x    2 root     root           80 Jul 11 14:26 wigig_update
-rw-r--r--    1 root     root            0 Jul 11 14:29 wla_2nd_status
-rw-r--r--    1 root     root           21 Jul 11 14:29 wla_channel
srwxr-xr-x    1 root     root            0 Jul 11 14:31 wpa_ctrl_28394-1
srwxr-xr-x    1 root     root            0 Jul 11 14:32 wpa_ctrl_8262-1
srwxr-xr-x    1 root     root            0 Apr 24 19:09 wpa_ctrl_8958-1
srwxr-xr-x    1 root     root            0 Jul 11 14:29 wpa_ctrl_9164-1
srwxr-xr-x    1 root     root            0 Apr 24 19:09 wpa_ctrl_9894-1
-rw-r--r--    1 root     root            9 Apr 24 19:09 wpspin
-rw-r--r--    1 root     root          217 Jul 11 14:27 xCloud_MAXmind
-rw-rw----    1 root     root            6 Jul 11 14:27 xagent.pid
-rw-rw----    1 root     root            6 Jul 11 14:27 xagent_watchdog.pid
-rw-r--r--    1 root     root          310 Jul 11 14:38 xml.txt
root@R9000:~#
root@R9000:~#
root@R9000:~/mnt/sda1/Library# ls -l
drwxrwxrwx    1 root     root            0 Jul 11 14:37 Application Support
root@R9000:~/mnt/sda1/Library/Application Support# ls -l
drwxrwxrwx    1 root     root         4096 Jul 11 14:37 Plex Media Server
root@R9000:~/mnt/sda1/Library/Application Support/Plex Media Server# ls -l
drwxrwxrwx    1 root     root         4096 Jul 11 14:37 Cache
drwxrwxrwx    1 root     root            0 Jul 11 14:37 Codecs
drwxrwxrwx    1 root     root            0 Jul 11 14:37 Crash Reports
drwxrwxrwx    1 root     root            0 Jul 11 14:37 Logs
drwxrwxrwx    1 root     root            0 Jul 11 14:37 Plug-in Support
drwxrwxrwx    1 root     root            0 Jul 11 14:37 Plug-ins
-rwxrwxrwx    1 root     root          310 Jul 11 14:37 Preferences.xml
-rwxrwxrwx    1 root     root            5 Jul 11 14:37 plexmediaserver.pid
root@R9000:~/mnt/sda1/Library/Application Support/Plex Media Server/Codecs# ls -l
drwxrwxrwx    1 root     root            0 Jul 11 14:41 99c90e0-3095-linux-armv7hf-sysv
drwxrwxrwx    1 root     root            0 Jul 11 14:41 EasyAudioEncoder-652-linux-armv7hf-sysv
root@R9000:~/mnt/sda1/Library/Application Support/Plex Media Server/Codecs/EasyAudioEncoder-652-linux-armv7hf-sysv#
root@R9000:~/mnt/sda1/Library/Application Support/Plex Media Server/Codecs/EasyAudioEncoder-652-linux-armv7hf-sysv# ls -l
root@R9000:~/mnt/sda1/Library/Application Support/Plex Media Server/Codecs/EasyAudioEncoder-652-linux-armv7hf-sysv/EasyAudioEncoder# ls -l
-rwxr-xr-x    1 root     root      1495316 Jul 11 14:41 EasyAudioEncoder
-rwxrwxrwx    1 root     root          136 Jul 11 14:41 eae-license.txt
Changing permissions of EasyAudioEncoder file from rwxr-xr-x to rwx-rwx-rwx doesn’t resolve the issue.
likely a problem with the amount of FREE SPACE
see also @ PMS on shield 2017 error transcoding dolby true hd similar issue with shield running out of space for detect intros
resolved by moving plex data from internal to larger usb3 thumb drive
The EasyAudioEncoder process is exiting immediately after launch
Jul 10, 2020 18:19:57.180 [0xb26ff460] INFO - CodecManager: starting EAE at "/tmp/mnt/sda1/pms-4d5cdcf6-a218-4569-aa3c-7f78ad3b731d/EasyAudioEncoder"
Jul 10, 2020 18:19:57.181 [0xb26ff460] DEBUG - Job running: '/tmp/mnt/sda1/Library/Application Support/Plex Media Server/Codecs/EasyAudioEncoder-652-linux-armv7hf-sysv/EasyAudioEncoder/EasyAudioEncoder'
Jul 10, 2020 18:19:57.197 [0xb26ff460] DEBUG - Jobs: Starting child process with pid 5691
Jul 10, 2020 18:19:57.197 [0xb3eff460] DEBUG - Jobs: '/tmp/mnt/sda1/Library/Application Support/Plex Media Server/Codecs/EasyAudioEncoder-652-linux-armv7hf-sysv/EasyAudioEncoder/EasyAudioEncoder' exit code for process 5691 is 9 (failure)
could be an issue with the binary file for the Netgear R9000
Thanks for tip but this is not the case:
Current USB Device: USB1 , My Book 25EE , STORAGE , Total space: 3.6T , Free space: 246.4G
And the conversion happens at external drive at /mnt/sda1/pms-c3354a89-b8aa-4af1-a7d6-1d6c1456a2e9 not on internal routers memory.
The path is probably wrong
There is /tmp before the /mnt
could you see if that mount path exists
/tmp/mnt/sda1
It goes somewhere:
root@R9000:/#
root@R9000:/# cd /tmp/mnt/sda1
root@R9000:~/mnt/sda1#
It’s like a redirect from /tmp/mnt/sda1 to /mnt/sda1.
Thanks - I will discuss with our development team
