Official plex doker image: commit 2d9b89c32cea9100f74e15a8f938825a9f4087de (Date: Sun Feb 19 15:15:54 2017 -0800)
Plex Server Version 1.5.5.3634
This error bellow happens after some time playing AC3 or EAC3 streams. To recover from error I need to do this: "kill -9 pgrep "EasyAudioEncode""
but this is short term fix because in next few minutes streaming will stop again with same error. I already have fs.inotify.max_user_watches=524288 so this is not related to error from other ticket mentioning EAC timoeuts.
Apr 25, 2017 11:30:02.014 [0x7f3a3abfa700] ERROR - [Transcoder] [ac3_eae @ 0x2fd4f40] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-df2bb8fb-531b-4d33-9822-f24996fca71b/EasyAudioEncoder/Convert to WAV (to 8ch or less)/ynqwgibcfo6byomw1w226ct1_27313-1-2.wav'
Apr 25, 2017 11:30:02.015 [0x7f3a35ffc700] ERROR - [Transcoder] [ac3_eae @ 0x2fd4f40] error reading output
Apr 25, 2017 11:30:02.016 [0x7f3a4d7fe700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Apr 25, 2017 11:30:02.029 [0x7f3a367fd700] ? - [Transcoder] [Parsed_inlineass_2 @ 0x2eb67a0] fontselect: Using default font family: (Arial, 400, 0) -> /usr/lib/plexmediaserver/Resources/Fonts/DejaVuSans-Regular.ttf, 0, DejaVuSans[Parsed_inlineass_2 @ 0x2eb67a0]
Apr 25, 2017 11:30:05.000 [0x7f3a38bf6700] ERROR - [Transcoder] [ac3_eae @ 0x2fd4f40] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-df2bb8fb-531b-4d33-9822-f24996fca71b/EasyAudioEncoder/Convert to WAV (to 8ch or less)/ynqwgibcfo6byomw1w226ct1_27313-1-3.wav'
Apr 25, 2017 11:30:05.001 [0x7f3a35ffc700] ERROR - [Transcoder] [ac3_eae @ 0x2fd4f40] error reading output
Apr 25, 2017 11:30:05.002 [0x7f3a4d7fe700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
I also installed a new Plex docker, wtih new database and everything but I still encountered same problem.
My solution is now to have a second Plex Server on windows(VM) and use it for transcoding. Hopefully Plex will release a fix soon…
Seems there’s another cause for he issue. I was using the default mount /transcode as the transcoding folder but EasyAudioEncode was still looking under /tmp. I fixed the issue by mounting /tmp -> /tmp and changing the transcoding folder from /transcode to /tmp.
Hope the develops look at this thread and push a permanent fix for it.
I’m facing the same issue. What is the status on this issue?
This occured while transcoding AC3 audio to AAC audio when requesting a .mkv video on Android with an AC3 audio track.
Attached my logs where Plex Media Server.log is the relevant one
You have exceeded the system limit on Number of directories that are added to the watch list
Sep 03, 2017 01:10:31.827 [0x7f20fbcb0700] DEBUG - [Notify] Now watching /volume1/Music/JT/iTunes/iTunes Media/Music/Soul Creation ft. Kenny Bobien
Sep 03, 2017 01:10:31.827 [0x7f20fbcb0700] ERROR - [Notify] Failed to add watch for /volume1/Music/JT/iTunes/iTunes Media/Music/Soul Creation ft. Kenny Bobien/Sunset Sessions (Deluxe Volume 2) disc 2 (28: No space left on device)
Sep 03, 2017 01:10:31.828 [0x7f20fbcb0700] ERROR - [Notify] Failed to add watch for /volume1/Music/JT/iTunes/iTunes Media/Music/Soul Migrantz (28: No space left on device)
Sep 03, 2017 01:10:31.828 [0x7f20fbcb0700] ERROR - [Notify] Failed to add watch for /volume1/Music/JT/iTunes/iTunes Media/Music/Soul Migrantz/Calling Chicago - EP (28: No space left on device)
Sep 03, 2017 01:10:31.828 [0x7f20fbcb0700] ERROR - [Notify] Failed to add watch for /volume1/Music/JT/iTunes/iTunes Media/Music/Soulfulicious (28: No space left on device)
etc
Easy Audio Encoder path would need to be added to the watch list and the limit was reached
Just to give you more info
You have successfully setup watch for 8192 directories and you have about 1000 that failed to get added
If I may augment here? If you need more than 8,192 directories for PMS to watch,
in /etc/sysctl.conf create the kernel tuning entry.
# For more information, see sysctl.conf(5) and sysctl.d(5).
fs.inotify.max_user_watches=16384
After making the entry, Reboot.
The above increases from 8192 to 16384.
Caution is advised on systems with < 4GB of RAM. This is because iNotify entries increase the size of the kernel. If too large, nothing will run and DSM will need to be fully reset.
Just so everyone is aware, this issue is still occurring on version 1.9.7.4460. I’m running the official Plex docker container on Ubuntu 17.10. I can’t sync anything to my mobile devices that has an EAC3 5.1 audio stream.
Logs attached.
I guess I’ll try to mount /tmp somewhere on my local file system when I get home from vacation in a week and report back if it works.
Logs attached.
Is eae process running?
Nov 26, 2017 22:21:23.000 [0x7f16837fb700] ERROR - [Transcoder] [eac3_eae @ 0x18ac180] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-8f54e2af-71f7-47b2-b9d3-e38a3d987449/EasyAudioEncoder/Convert to WAV (to 8ch or less)/a15c484b-ac3f-4da7-a2fc-e42836700251_7570-1-0.wav'
Best to get logs and test it after restart - that way other issues like number of watched directories could be checked for being over the limit - also can see the attempt to start eae
So I didn’t think about checking for the EAE process before updating the docker image and replacing the container (since I was out of date). After updating, I’m running v1.10.1.4561.
Everything seems to have started up correctly. I tested a couple files with EAC3 and they worked. And in htop I see “Plex EAE Service” running. So that’s weird.
I’m still attaching the new log from restart. Guidance as to how to figure out if I’m over the file watch limit (even though I do not think I am) would be helpful. Also, I’m a linux noob, any help in detecting if the EAE Service is dead and making the container auto-restart would be great, in case this gets flaky. The behavior manifests itself to the roku client as getting stuck at 13% buffering, so if that happens again I’ll check to see if the EAE Service is running to see if I can repro this somehow.
If there is a problem with the transcoder starting then the roku 13% may show. Would need logs for that and when it is arising - perhaps with logs from both sides - PMS and Roku app
With regards to the notifier system limit - that should not be the case for you as you appear not to have automatic library updates enabled
Dec 07, 2017 18:55:55.152 [0x7f92f5ffe700] INFO - LibraryUpdateManager path watching is disabled
Ok, it happened again today. Tried to watch a .mkv with EAC3 5.1 using my Roku and it got stuck at 13%.
I checked in htop and the Plex EAE Service is running. Log was again full of errors about EAE timeout errors, and unable to read a .wav file in the /tmp directory.
