Bug with Scan Library Files and Locked Titles
Server Version#: 1.21.0.3711
Player Version#: X
With the latest version; if you select Scan Library Files for a specific library the manually set Title value that is locked is still wiped out.
For example; I spent hours setting the proper titles on my movie library. I executed Scan Library Files and it seems any title that I manually set and doesn’t have found meta data from before are changed back.
I verified this again by double checking that the lock icon is golden/highlighted and tried again. Error repeated.
I am having the same problem. My home movie gets imported and then the title changes to the actual file name. Very odd.
One thing it has helped to change the file names to the appropriate syntax. Ex; The Movie Title (2001).mp4
Once changed and synced in the Plex menu, they stopped being replaced.
