I built my first Rasplex box (and indeed my first Raspberry Pi) at the weekend.
It works flawlessly over ethernet, only trouble is my USB Wi-Fi adapter doesn't work (it's this one), plugging it into my iMac and checking System Information reveals the chipset is a Ralink RT5370 and there are apparently some known issues with Ralink adapters which can be fixed by disabling power management (explained here).
Trouble is everything I can find tells me to do this in /etc/network/interfaces which would seem not to exist on my Pi. It there somewhere else I can disable power management for this device on Rasplex?
Here's my log if it's of any use (/var/messages/log):
Jan 1 01:00:04 rasplex syslog.info syslogd started: BusyBox v1.21.1
Jan 1 01:00:04 rasplex user.notice Boot: ### starting udev daemon ###
Jan 1 01:00:04 rasplex user.notice Boot: ### Starting Syslog daemon ###
Jan 1 01:00:04 rasplex user.notice Boot: ### Starting cron daemon ###
Jan 1 01:00:04 rasplex user.notice Boot: ### Starting Kernellog daemon ###
Jan 1 01:00:04 rasplex user.notice kernel: klogd started: BusyBox v1.21.1 (2014-05-19 12:11:55 EDT)
Jan 1 01:00:04 rasplex user.info kernel: [ 0.000000] Booting Linux on physical CPU 0x0
Jan 1 01:00:04 rasplex user.notice kernel: [ 0.000000] Linux version 3.10.20 (dale.hamel@Mainframe) (gcc version 4.7.3 (GCC) ) #1 PREEMPT Mon May 19 12:11:33 EDT 2014
Jan 1 01:00:04 rasplex user.warn kernel: [ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
Jan 1 01:00:04 rasplex user.warn kernel: [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Jan 1 01:00:04 rasplex user.warn kernel: [ 0.000000] Machine: BCM2708
Jan 1 01:00:04 rasplex user.warn kernel: [ 0.000000] Memory policy: ECC disabled, Data cache writeback
Jan 1 01:00:04 rasplex user.debug kernel: [ 0.000000] On node 0 totalpages: 79872
Jan 1 01:00:04 rasplex user.debug kernel: [ 0.000000] free_area_init_node: node 0, pgdat c0b06008, node_mem_map c0b87000
Jan 1 01:00:04 rasplex user.debug kernel: [ 0.000000] Normal zone: 624 pages used for memmap
Jan 1 01:00:04 rasplex user.debug kernel: [ 0.000000] Normal zone: 0 pages reserved
Jan 1 01:00:04 rasplex user.debug kernel: [ 0.000000] Normal zone: 79872 pages, LIFO batch:15
Jan 1 01:00:04 rasplex user.debug kernel: [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
Jan 1 01:00:04 rasplex user.debug kernel: [ 0.000000] pcpu-alloc: [0] 0
Jan 1 01:00:04 rasplex user.warn kernel: [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 79248
Jan 1 01:00:04 rasplex user.notice kernel: [ 0.000000] Kernel command line: dwc_otg.lpm_enable=0 root=/dev/ram0 rdinit=/init BOOT_IMAGE=/kernel.img dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1184 bcm2708_fb.fbheight=624 bcm2708.boardrev=0xe bcm2708.serial=0x44819d41 smsc
Jan 1 01:00:04 rasplex user.info kernel: [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
Jan 1 01:00:04 rasplex user.info kernel: [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Jan 1 01:00:04 rasplex user.info kernel: [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Jan 1 01:00:04 rasplex user.info kernel: [ 0.000000] Memory: 312MB = 312MB total
Jan 1 01:00:04 rasplex user.notice kernel: [ 0.000000] Memory: 304732k/304732k available, 14756k reserved, 0K highmem
Jan 1 01:00:04 rasplex user.notice kernel: [ 0.000000] Virtual kernel memory layout:
Jan 1 01:00:04 rasplex user.notice kernel: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
Jan 1 01:00:04 rasplex user.notice kernel: [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
Jan 1 01:00:04 rasplex user.notice kernel: [ 0.000000] vmalloc : 0xd4000000 - 0xff000000 ( 688 MB)
Jan 1 01:00:04 rasplex user.notice kernel: [ 0.000000] lowmem : 0xc0000000 - 0xd3800000 ( 312 MB)
Jan 1 01:00:04 rasplex user.notice kernel: [ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
Jan 1 01:00:04 rasplex user.notice kernel: [ 0.000000] .text : 0xc0008000 - 0xc07d1f44 (7976 kB)
Jan 1 01:00:04 rasplex user.notice kernel: [ 0.000000] .init : 0xc07d2000 - 0xc0aae744 (2930 kB)
Jan 1 01:00:04 rasplex user.notice kernel: [ 0.000000] .data : 0xc0ab0000 - 0xc0b0ea68 ( 379 kB)
Jan 1 01:00:04 rasplex user.notice kernel: [ 0.000000] .bss : 0xc0b0ea68 - 0xc0b86ef8 ( 482 kB)
Jan 1 01:00:04 rasplex user.info kernel: [ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Jan 1 01:00:04 rasplex user.info kernel: [ 0.000000] NR_IRQS:330
Jan 1 01:00:04 rasplex user.info kernel: [ 0.000000] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
Jan 1 01:00:04 rasplex user.info kernel: [ 0.000000] Switching to timer-based delay loop
Jan 1 01:00:04 rasplex user.info kernel: [ 0.000000] Console: colour dummy device 80x30
Jan 1 01:00:04 rasplex user.info kernel: [ 0.000000] console [tty0] enabled
Jan 1 01:00:04 rasplex user.info kernel: [ 0.000468] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=10000)
Jan 1 01:00:04 rasplex user.info kernel: [ 0.000491] pid_max: default: 32768 minimum: 301
Jan 1 01:00:04 rasplex user.info kernel: [ 0.000774] Mount-cache hash table entries: 512
Jan 1 01:00:04 rasplex user.info kernel: [ 0.001578] CPU: Testing write buffer coherency: ok
Jan 1 01:00:04 rasplex user.info kernel: [ 0.001656] ftrace: allocating 21082 entries in 62 pages
Jan 1 01:00:04 rasplex user.info kernel: [ 0.119443] Setting up static identity map for 0xc0644018 - 0xc0644050
Jan 1 01:00:04 rasplex user.info kernel: [ 0.129220] devtmpfs: initialized
Jan 1 01:00:04 rasplex user.info kernel: [ 0.150427] xor: measuring software checksum speed
Jan 1 01:00:04 rasplex user.info kernel: [ 0.249384] arm4regs : 972.400 MB/sec
Jan 1 01:00:04 rasplex user.info kernel: [ 0.349420] 8regs : 470.400 MB/sec
Jan 1 01:00:04 rasplex user.info kernel: [ 0.449485] 32regs : 401.200 MB/sec
Jan 1 01:00:04 rasplex user.info kernel: [ 0.449504] xor: using function: arm4regs (972.400 MB/sec)
Jan 1 01:00:04 rasplex user.info kernel: [ 0.449824] NET: Registered protocol family 16
Jan 1 01:00:04 rasplex user.info kernel: [ 0.454827] DMA: preallocated 4096 KiB pool for atomic coherent allocations
Jan 1 01:00:04 rasplex user.warn kernel: [ 0.458408] bcm2708.uart_clock = 0
Jan 1 01:00:04 rasplex user.info kernel: [ 0.466011] mailbox: Broadcom VideoCore Mailbox driver
Jan 1 01:00:04 rasplex user.info kernel: [ 0.466124] bcm2708_vcio: mailbox at f200b880
Jan 1 01:00:04 rasplex user.info kernel: [ 0.466465] bcm_power: Broadcom power driver
Jan 1 01:00:04 rasplex user.warn kernel: [ 0.466491] bcm_power_open() -> 0
Jan 1 01:00:04 rasplex user.warn kernel: [ 0.466502] bcm_power_request(0, 8)
Jan 1 01:00:04 rasplex user.warn kernel: [ 0.967201] bcm_mailbox_read -> 00000080, 0
Jan 1 01:00:04 rasplex user.warn kernel: [ 0.967223] bcm_power_request -> 0
Jan 1 01:00:04 rasplex user.info kernel: [ 0.967235] Serial: AMBA PL011 UART driver
Jan 1 01:00:04 rasplex user.info kernel: [ 0.967390] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83) is a PL011 rev3
Jan 1 01:00:04 rasplex user.info kernel: [ 1.052112] bio: create slab at 0
Jan 1 01:00:04 rasplex user.warn kernel: [ 1.221452] raid6: int32x1 46 MB/s
Jan 1 01:00:04 rasplex user.warn kernel: [ 1.391705] raid6: int32x2 60 MB/s
Jan 1 01:00:04 rasplex user.warn kernel: [ 1.561566] raid6: int32x4 61 MB/s
Jan 1 01:00:04 rasplex user.warn kernel: [ 1.732236] raid6: int32x8 58 MB/s
Jan 1 01:00:04 rasplex user.warn kernel: [ 1.732253] raid6: using algorithm int32x4 (61 MB/s)
Jan 1 01:00:04 rasplex user.warn kernel: [ 1.732264] raid6: using intx1 recovery algorithm
Jan 1 01:00:04 rasplex user.notice kernel: [ 1.734211] SCSI subsystem initialized
Jan 1 01:00:04 rasplex user.info kernel: [ 1.735746] usbcore: registered new interface driver usbfs
Jan 1 01:00:04 rasplex user.info kernel: [ 1.736109] usbcore: registered new interface driver hub
Jan 1 01:00:04 rasplex user.info kernel: [ 1.736538] usbcore: registered new device driver usb
Jan 1 01:00:04 rasplex user.info kernel: [ 1.740990] Switching to clocksource stc
Jan 1 01:00:04 rasplex user.info kernel: [ 1.816400] NET: Registered protocol family 2
Jan 1 01:00:04 rasplex user.info kernel: [ 1.817190] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
Jan 1 01:00:04 rasplex user.info kernel: [ 1.817323] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
Jan 1 01:00:04 rasplex user.info kernel: [ 1.817400] TCP: Hash tables configured (established 4096 bind 4096)
Jan 1 01:00:04 rasplex user.info kernel: [ 1.817480] TCP: reno registered
Jan 1 01:00:04 rasplex user.info kernel: [ 1.817506] UDP hash table entries: 256 (order: 0, 4096 bytes)
Jan 1 01:00:04 rasplex user.info kernel: [ 1.817537] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
Jan 1 01:00:04 rasplex user.info kernel: [ 1.817928] NET: Registered protocol family 1
Jan 1 01:00:04 rasplex user.info kernel: [ 1.818541] RPC: Registered named UNIX socket transport module.
Jan 1 01:00:04 rasplex user.info kernel: [ 1.818565] RPC: Registered udp transport module.
Jan 1 01:00:04 rasplex user.info kernel: [ 1.818574] RPC: Registered tcp transport module.
Jan 1 01:00:04 rasplex user.info kernel: [ 1.818583] RPC: Registered tcp NFSv4.1 backchannel transport module.
Jan 1 01:00:04 rasplex user.info kernel: [ 1.843155] bcm2708_dma: DMA manager at f2007000
Jan 1 01:00:04 rasplex user.info kernel: [ 1.843598] bcm2708_gpio: bcm2708_gpio_probe c0abd2f0
Jan 1 01:00:04 rasplex user.warn kernel: [ 1.844582] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
Jan 1 01:00:04 rasplex user.debug kernel: [ 1.845337] major device number 252
Jan 1 01:00:04 rasplex user.debug kernel: [ 1.845359] vma list size 12, page list size 2008, page size 4096
Jan 1 01:00:04 rasplex user.debug kernel: [ 1.845378] allocated dma channel 2 (f2007200), initial state 00000008
Jan 1 01:00:04 rasplex user.debug kernel: [ 1.845387] post-reset 00000008
Jan 1 01:00:04 rasplex user.info kernel: [ 1.986531] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Jan 1 01:00:04 rasplex user.notice kernel: [ 1.992207] NFS: Registering the id_resolver key type
Jan 1 01:00:04 rasplex user.notice kernel: [ 1.992320] Key type id_resolver registered
Jan 1 01:00:04 rasplex user.notice kernel: [ 1.992337] Key type id_legacy registered
Jan 1 01:00:04 rasplex user.info kernel: [ 1.994345] fuse init (API version 7.22)
Jan 1 01:00:04 rasplex user.info kernel: [ 1.997340] JFS: nTxBlock = 2380, nTxLock = 19045
Jan 1 01:00:04 rasplex user.info kernel: [ 1.998564] SGI XFS with security attributes, large block/inode numbers, no debug enabled
Jan 1 01:00:04 rasplex user.info kernel: [ 2.008250] bio: create slab at 1
Jan 1 01:00:04 rasplex user.info kernel: [ 2.011969] Btrfs loaded
Jan 1 01:00:04 rasplex user.info kernel: [ 2.012043] msgmni has been set to 595
Jan 1 01:00:04 rasplex user.info kernel: [ 2.016040] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
Jan 1 01:00:04 rasplex user.info kernel: [ 2.016071] io scheduler noop registered (default)
Jan 1 01:00:04 rasplex user.info kernel: [ 2.016084] io scheduler deadline registered
Jan 1 01:00:04 rasplex user.info kernel: [ 2.016161] io scheduler cfq registered
Jan 1 01:00:04 rasplex user.info kernel: [ 2.016757] BCM2708FB: allocated DMA memory 52610000
Jan 1 01:00:04 rasplex user.info kernel: [ 2.016782] BCM2708FB: allocated DMA channel 0 @ f2007000
Jan 1 01:00:04 rasplex user.info kernel: [ 2.038426] Console: switching to colour frame buffer device 148x39
Jan 1 01:00:04 rasplex user.info kernel: [ 2.045376] bcm2708_rng_init=d4582000
Jan 1 01:00:04 rasplex user.info kernel: [ 2.064190] brd: module loaded
Jan 1 01:00:04 rasplex user.info kernel: [ 2.064695] loop: module loaded
Jan 1 01:00:04 rasplex user.info kernel: [ 2.065015] nbd: registered device at major 43
Jan 1 01:00:04 rasplex user.info kernel: [ 2.084308] vchiq: vchiq_init_state: slot_zero = 0xd4004000, is_master = 0
Jan 1 01:00:04 rasplex user.info kernel: [ 2.084973] Loading iSCSI transport class v2.0-870.
Jan 1 01:00:04 rasplex user.notice kernel: [ 2.088053] iscsi: registered transport (tcp)
Jan 1 01:00:04 rasplex user.info kernel: [ 2.091785] bcm2708_spi bcm2708_spi.0: master is unqueued, this is deprecated
Jan 1 01:00:04 rasplex user.info kernel: [ 2.094222] bcm2708_spi bcm2708_spi.0: SPI Controller at 0x20204000 (irq 80)
Jan 1 01:00:04 rasplex user.info kernel: [ 2.094702] tun: Universal TUN/TAP device driver, 1.6
Jan 1 01:00:04 rasplex user.info kernel: [ 2.094724] tun: (C) 1999-2004 Max Krasnyansky
Jan 1 01:00:04 rasplex user.info kernel: [ 2.095364] PPP generic driver version 2.4.2
Jan 1 01:00:04 rasplex user.info kernel: [ 2.096568] usbcore: registered new interface driver smsc95xx
Jan 1 01:00:04 rasplex user.info kernel: [ 2.096689] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
Jan 1 01:00:04 rasplex user.warn kernel: [ 2.296791] Core Release: 2.80a
Jan 1 01:00:04 rasplex user.warn kernel: [ 2.296819] Setting default values for core params
Jan 1 01:00:04 rasplex user.warn kernel: [ 2.296867] Finished setting default values for core params
Jan 1 01:00:04 rasplex user.warn kernel: [ 2.497032] Using Buffer DMA mode
Jan 1 01:00:04 rasplex user.warn kernel: [ 2.497057] Periodic Transfer Interrupt Enhancement - disabled
Jan 1 01:00:04 rasplex user.warn kernel: [ 2.497067] Multiprocessor Interrupt Enhancement - disabled
Jan 1 01:00:04 rasplex user.warn kernel: [ 2.497079] OTG VER PARAM: 0, OTG VER FLAG: 0
Jan 1 01:00:04 rasplex user.warn kernel: [ 2.497096] Dedicated Tx FIFOs mode
Jan 1 01:00:04 rasplex user.debug kernel: [ 2.497312] dwc_otg: Microframe scheduler enabled
Jan 1 01:00:04 rasplex user.info kernel: [ 2.497371] dwc_otg bcm2708_usb: DWC OTG Controller
Jan 1 01:00:04 rasplex user.info kernel: [ 2.497430] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
Jan 1 01:00:04 rasplex user.info kernel: [ 2.497492] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
Jan 1 01:00:04 rasplex user.warn kernel: [ 2.497535] Init: Port Power? op_state=1
Jan 1 01:00:04 rasplex user.warn kernel: [ 2.497545] Init: Power Port (0)
Jan 1 01:00:04 rasplex user.info kernel: [ 2.497679] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Jan 1 01:00:04 rasplex user.info kernel: [ 2.497703] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jan 1 01:00:04 rasplex user.info kernel: [ 2.497719] usb usb1: Product: DWC OTG Controller
Jan 1 01:00:04 rasplex user.info kernel: [ 2.497734] usb usb1: Manufacturer: Linux 3.10.20 dwc_otg_hcd
Jan 1 01:00:04 rasplex user.info kernel: [ 2.497748] usb usb1: SerialNumber: bcm2708_usb
Jan 1 01:00:04 rasplex user.info kernel: [ 2.499000] hub 1-0:1.0: USB hub found
Jan 1 01:00:04 rasplex user.info kernel: [ 2.499065] hub 1-0:1.0: 1 port detected
Jan 1 01:00:04 rasplex user.debug kernel: [ 2.499747] dwc_otg: FIQ enabled
Jan 1 01:00:04 rasplex user.debug kernel: [ 2.499771] dwc_otg: NAK holdoff enabled
Jan 1 01:00:04 rasplex user.debug kernel: [ 2.499781] dwc_otg: FIQ split fix enabled
Jan 1 01:00:04 rasplex user.debug kernel: [ 2.499810] Module dwc_common_port init
Jan 1 01:00:04 rasplex user.info kernel: [ 2.500464] usbcore: registered new interface driver usb-storage
Jan 1 01:00:04 rasplex user.info kernel: [ 2.501248] mousedev: PS/2 mouse device common for all mice
Jan 1 01:00:04 rasplex user.info kernel: [ 2.502102] i2c /dev entries driver
Jan 1 01:00:04 rasplex user.warn kernel: [ 2.502539] bcm2708_i2c_init_pinmode(0,0)
Jan 1 01:00:04 rasplex user.warn kernel: [ 2.502562] bcm2708_i2c_init_pinmode(0,1)
Jan 1 01:00:04 rasplex user.info kernel: [ 2.503529] bcm2708_i2c bcm2708_i2c.0: BSC0 Controller at 0x20205000 (irq 79) (baudrate 100k)
Jan 1 01:00:04 rasplex user.warn kernel: [ 2.503611] bcm2708_i2c_init_pinmode(1,2)
Jan 1 01:00:04 rasplex user.warn kernel: [ 2.503625] bcm2708_i2c_init_pinmode(1,3)
Jan 1 01:00:04 rasplex user.info kernel: [ 2.504562] bcm2708_i2c bcm2708_i2c.1: BSC1 Controller at 0x20804000 (irq 79) (baudrate 100k)
Jan 1 01:00:04 rasplex user.info kernel: [ 2.506414] bcm2835-cpufreq: min=700000 max=700000 cur=700000
Jan 1 01:00:04 rasplex user.info kernel: [ 2.506533] bcm2835-cpufreq: switching to governor ondemand
Jan 1 01:00:04 rasplex user.info kernel: [ 2.506550] bcm2835-cpufreq: switching to governor ondemand
Jan 1 01:00:04 rasplex user.info kernel: [ 2.506661] cpuidle: using governor ladder
Jan 1 01:00:04 rasplex user.info kernel: [ 2.506679] cpuidle: using governor menu
Jan 1 01:00:04 rasplex user.info kernel: [ 2.506982] sdhci: Secure Digital Host Controller Interface driver
Jan 1 01:00:04 rasplex user.info kernel: [ 2.507002] sdhci: Copyright(c) Pierre Ossman
Jan 1 01:00:04 rasplex user.warn kernel: [ 2.507101] sdhci: Enable low-latency mode
Jan 1 01:00:04 rasplex user.info kernel: [ 2.551105] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
Jan 1 01:00:04 rasplex user.info kernel: [ 2.551250] mmc0: BCM2708 SDHC host at 0x20300000 DMA 4 IRQ 20
Jan 1 01:00:04 rasplex user.info kernel: [ 2.553805] sdhci-pltfm: SDHCI platform and OF driver helper
Jan 1 01:00:04 rasplex user.info kernel: [ 2.566930] hidraw: raw HID events driver (C) Jiri Kosina
Jan 1 01:00:04 rasplex user.info kernel: [ 2.588020] usbcore: registered new interface driver usbhid
Jan 1 01:00:04 rasplex user.info kernel: [ 2.588047] usbhid: USB HID core driver
Jan 1 01:00:04 rasplex user.info kernel: [ 2.589331] zram: Created 1 device(s) ...
Jan 1 01:00:04 rasplex user.info kernel: [ 2.589408] Netfilter messages via NETLINK v0.30.
Jan 1 01:00:04 rasplex user.info kernel: [ 2.589534] nf_conntrack version 0.5.0 (4761 buckets, 19044 max)
Jan 1 01:00:04 rasplex user.info kernel: [ 2.590391] ctnetlink v0.93: registering with nfnetlink.
Jan 1 01:00:04 rasplex user.info kernel: [ 2.590650] TCP: cubic registered
Jan 1 01:00:04 rasplex user.info kernel: [ 2.594269] NET: Registered protocol family 10
Jan 1 01:00:04 rasplex user.info kernel: [ 2.595488] NET: Registered protocol family 17
Jan 1 01:00:04 rasplex user.notice kernel: [ 2.595670] Key type dns_resolver registered
Jan 1 01:00:04 rasplex user.info kernel: [ 2.596184] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
Jan 1 01:00:04 rasplex user.err kernel: [ 2.598722] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
Jan 1 01:00:04 rasplex user.info kernel: [ 2.606241] mmc0: new high speed SDHC card at address b368
Jan 1 01:00:04 rasplex user.info kernel: [ 2.611633] mmcblk0: mmc0:b368 SDC 7.45 GiB
Jan 1 01:00:04 rasplex user.info kernel: [ 2.612234] Freeing unused kernel memory: 2928K (c07d2000 - c0aae000)
Jan 1 01:00:04 rasplex user.info kernel: [ 2.614340] mmcblk0: p1 p2
Jan 1 01:00:04 rasplex user.warn kernel: [ 2.691331] Indeed it is in host mode hprt0 = 00021501
Jan 1 01:00:04 rasplex user.info kernel: [ 2.901165] usb 1-1: new high-speed USB device number 2 using dwc_otg
Jan 1 01:00:04 rasplex user.warn kernel: [ 2.901395] Indeed it is in host mode hprt0 = 00001101
Jan 1 01:00:04 rasplex user.err kernel: [ 3.158587] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
Jan 1 01:00:04 rasplex user.err kernel: [ 3.159465] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
Jan 1 01:00:04 rasplex user.info kernel: [ 3.162035] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
Jan 1 01:00:04 rasplex user.info kernel: [ 3.162089] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jan 1 01:00:04 rasplex user.info kernel: [ 3.165872] hub 1-1:1.0: USB hub found
Jan 1 01:00:04 rasplex user.info kernel: [ 3.166194] hub 1-1:1.0: 5 ports detected
Jan 1 01:00:04 rasplex user.info kernel: [ 3.350109] EXT4-fs (mmcblk0p2): recovery complete
Jan 1 01:00:04 rasplex user.info kernel: [ 3.357129] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Jan 1 01:00:04 rasplex user.info kernel: [ 3.441444] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
Jan 1 01:00:04 rasplex user.info kernel: [ 3.541873] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
Jan 1 01:00:04 rasplex user.info kernel: [ 3.541908] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jan 1 01:00:04 rasplex user.info kernel: [ 3.549364] smsc95xx v1.0.4
Jan 1 01:00:04 rasplex user.info kernel: [ 3.612687] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:81:9d:41
Jan 1 01:00:04 rasplex user.info kernel: [ 3.691385] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
Jan 1 01:00:04 rasplex user.info kernel: [ 3.810008] usb 1-1.2: New USB device found, idVendor=148f, idProduct=5370
Jan 1 01:00:04 rasplex user.info kernel: [ 3.810045] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jan 1 01:00:04 rasplex user.info kernel: [ 3.810062] usb 1-1.2: Product: 802.11 n WLAN
Jan 1 01:00:04 rasplex user.info kernel: [ 3.810077] usb 1-1.2: Manufacturer: Ralink
Jan 1 01:00:04 rasplex user.info kernel: [ 3.810091] usb 1-1.2: SerialNumber: 1.0
Jan 1 01:00:04 rasplex user.info kernel: [ 3.912033] usb 1-1.3: new low-speed USB device number 5 using dwc_otg
Jan 1 01:00:04 rasplex user.info kernel: [ 4.022156] usb 1-1.3: New USB device found, idVendor=0603, idProduct=0002
Jan 1 01:00:04 rasplex user.info kernel: [ 4.022191] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Jan 1 01:00:04 rasplex user.info kernel: [ 4.022207] usb 1-1.3: Product: USB Composite Device
Jan 1 01:00:04 rasplex user.info kernel: [ 4.022221] usb 1-1.3: Manufacturer: SINO WEALTH
Jan 1 01:00:04 rasplex user.info kernel: [ 4.042651] input: SINO WEALTH USB Composite Device as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.0/input/input0
Jan 1 01:00:04 rasplex user.info kernel: [ 4.044028] hid-generic 0003:0603:0002.0001: input,hidraw0: USB HID v1.10 Keyboard [SINO WEALTH USB Composite Device] on usb-bcm2708_usb-1.3/input0
Jan 1 01:00:04 rasplex user.info kernel: [ 4.069425] input: SINO WEALTH USB Composite Device as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.1/input/input1
Jan 1 01:00:04 rasplex user.info kernel: [ 4.073886] hid-generic 0003:0603:0002.0002: input,hiddev0,hidraw1: USB HID v1.10 Mouse [SINO WEALTH USB Composite Device] on usb-bcm2708_usb-1.3/input1
Jan 1 01:00:04 rasplex daemon.info kernel: [ 4.727213] systemd-udevd[823]: starting version 208
Jan 1 01:00:04 rasplex user.notice Boot: ### request udev events from the kernel (type: subsystems) ###
Jan 1 01:00:04 rasplex user.notice Boot: ### request udev events from the kernel (type: devices) ###
Jan 1 01:00:05 rasplex user.notice Boot: ### watching udev event queue from the kernel ###
Jan 1 01:00:05 rasplex user.notice Boot: ### Starting D-BUS ###
Jan 1 01:00:05 rasplex user.notice Boot: ### Starting Fuse ###
Jan 1 01:00:06 rasplex user.notice Boot: ### starting loopback device ###
Jan 1 01:00:06 rasplex user.info kernel: [ 6.283202] cfg80211: Calling CRDA to update world regulatory domain
Jan 1 01:00:06 rasplex user.notice Boot: ### loading kernel modules ###
Jan 1 01:00:06 rasplex user.notice Boot: ### creating initial connman settings file ###
Jan 1 01:00:06 rasplex user.notice Boot: ### Setup hostname ###
Jan 1 01:00:06 rasplex user.notice Boot: ### start rpcbind daemon ###
Jan 1 01:00:06 rasplex user.info kernel: [ 6.835470] lirc_dev: IR Remote Control driver registered, major 248
Jan 1 01:00:06 rasplex user.warn kernel: [ 6.865994] lirc_rpi: module is from the staging directory, the quality is unknown, you have been warned.
Jan 1 01:00:06 rasplex user.notice Boot: ### Activating swap... please wait ###
Jan 1 01:00:06 rasplex user.notice Boot: ### starting Connection manager ###
Jan 1 01:00:07 rasplex user.info kernel: [ 7.301385] usb 1-1.2: reset high-speed USB device number 4 using dwc_otg
Jan 1 01:00:07 rasplex user.info kernel: [ 7.412378] ieee80211 phy0: rt2x00_set_rt: Info - RT chipset 5390, rev 0502 detected
Jan 1 01:00:07 rasplex user.info kernel: [ 7.448196] ieee80211 phy0: rt2x00_set_rf: Info - RF chipset 5370 detected
Jan 1 01:00:07 rasplex user.debug kernel: [ 7.462092] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
Jan 1 01:00:07 rasplex user.info kernel: [ 7.487976] usbcore: registered new interface driver rt2800usb
Jan 1 01:00:07 rasplex user.notice Boot: ### enable swap ###
Jan 1 01:00:07 rasplex user.notice Boot: ### Starting SSH Server ###
Jan 1 01:00:07 rasplex user.info kernel: [ 7.891281] lirc_rpi: auto-detected active high receiver on GPIO pin 18
Jan 1 01:00:07 rasplex user.info kernel: [ 7.891699] lirc_rpi lirc_rpi.0: lirc_dev: driver lirc_rpi registered at minor = 0
Jan 1 01:00:07 rasplex user.info kernel: [ 7.891719] lirc_rpi: driver registered!
Jan 1 01:00:08 rasplex user.notice Boot: ### starting eventlircd ###
Jan 1 01:00:08 rasplex user.notice Boot: ### Starting Avahi Daemon ###
Jan 1 01:00:08 rasplex user.notice Boot: ### Starting bluetooth daemon ###
Jan 1 01:00:08 rasplex user.notice Boot: ### clean up log files ###
Jan 1 01:00:08 rasplex user.notice Boot: ### Starting obexd ###
Jan 1 01:00:08 rasplex user.notice Boot: ### starting XBMC ###
Jan 1 01:00:08 rasplex daemon.info bluetoothd[961]: Bluetooth daemon 5.10
Jan 1 01:00:08 rasplex user.notice Boot: ### Wait for network ###
Jan 1 01:00:08 rasplex daemon.info avahi-daemon[995]: Found user 'avahi' (UID 495) and group 'avahi' (GID 495).
Jan 1 01:00:08 rasplex daemon.info avahi-daemon[995]: Successfully dropped root privileges.
Jan 1 01:00:08 rasplex daemon.info avahi-daemon[995]: avahi-daemon 0.6.31 starting up.
Jan 1 01:00:08 rasplex daemon.warn avahi-daemon[995]: WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
Jan 1 01:00:08 rasplex user.info kernel: [ 8.848046] input: lircd as /devices/virtual/input/input2
Jan 1 01:00:08 rasplex daemon.warn lircd-0.9.1-git[984]: garbage after 'name' token in line 378 ignored
Jan 1 01:00:08 rasplex daemon.info connmand[911]: Connection Manager version 1.18
Jan 1 01:00:08 rasplex daemon.warn avahi-daemon[995]: Failed to open /etc/resolv.conf: No such file or directory
Jan 1 01:00:08 rasplex daemon.info avahi-daemon[995]: Loading service file /etc/avahi/services/sftp-ssh.service.
Jan 1 01:00:08 rasplex daemon.info avahi-daemon[995]: Network interface enumeration completed.
Jan 1 01:00:08 rasplex daemon.warn lircd-0.9.1-git[984]: invalid code found for Xbox: KEY_PAUSE
Jan 1 01:00:08 rasplex daemon.info avahi-daemon[995]: Server startup complete. Host name is RasPlex.local. Local service cookie is 1057795632.
Jan 1 01:00:08 rasplex daemon.info avahi-daemon[995]: Service "RasPlex" (/etc/avahi/services/sftp-ssh.service) successfully established.
Jan 1 01:00:08 rasplex daemon.notice lircd-0.9.1-git[1003]: lircd(default) ready, using /var/run/lirc/lircd-lirc0
Jan 1 01:00:08 rasplex daemon.info obexd[965]: OBEX daemon 5.10
Jan 1 01:00:09 rasplex user.info kernel: [ 9.219120] ip_tables: (C) 2000-2006 Netfilter Core Team
Jan 1 01:00:09 rasplex user.info kernel: [ 9.379484] Bluetooth: Core ver 2.16
Jan 1 01:00:09 rasplex user.info kernel: [ 9.395573] NET: Registered protocol family 31
Jan 1 01:00:09 rasplex user.info kernel: [ 9.395608] Bluetooth: HCI device and connection manager initialized
Jan 1 01:00:09 rasplex user.info kernel: [ 9.395706] Bluetooth: HCI socket layer initialized
Jan 1 01:00:09 rasplex user.info kernel: [ 9.395766] Bluetooth: L2CAP socket layer initialized
Jan 1 01:00:09 rasplex user.info kernel: [ 9.395846] Bluetooth: SCO socket layer initialized
Jan 1 01:00:09 rasplex daemon.info bluetoothd[961]: Starting SDP server
Jan 1 01:00:09 rasplex daemon.err connmand[911]: iptables support missing error 2 (No such file or directory)
Jan 1 01:00:09 rasplex daemon.warn connmand[911]: Failed to flush table 'mangle': Invalid argument
Jan 1 01:00:09 rasplex daemon.warn bluetoothd[961]: kernel lacks bnep-protocol support
Jan 1 01:00:09 rasplex daemon.warn bluetoothd[961]: System does not support network plugin
Jan 1 01:00:09 rasplex daemon.err bluetoothd[961]: Failed to open RFKILL control device
Jan 1 01:00:09 rasplex daemon.info bluetoothd[961]: Bluetooth management interface 1.3 initialized
Jan 1 01:00:09 rasplex user.info kernel: [ 9.902343] Adding 255996k swap on /storage/.cache/swapfile. Priority:10000 extents:3 across:280572k SSFS
Jan 1 01:00:09 rasplex daemon.warn connmand[911]: Failed to install iptables rules: Invalid argument
Jan 1 01:00:09 rasplex daemon.info connmand[911]: Checking loopback interface settings
Jan 1 01:00:09 rasplex daemon.info connmand[911]: System hostname is RasPlex
Jan 1 01:00:09 rasplex daemon.notice dbus[851]: [system] Activating service name='net.connman.vpn' (using servicehelper)
Jan 1 01:00:09 rasplex daemon.err connmand[911]: Failed to open RFKILL control device
Jan 1 01:00:09 rasplex daemon.info connmand[911]: lo {newlink} index 1 operstate 0
Jan 1 01:00:09 rasplex daemon.notice dbus[851]: [system] Activating service name='fi.w1.wpa_supplicant1' (using servicehelper)
Jan 1 01:00:09 rasplex daemon.info connmand[911]: eth0 {create} index 2 type 1
Jan 1 01:00:09 rasplex daemon.info connmand[911]: eth0 {update} flags 4098
Jan 1 01:00:09 rasplex daemon.info connmand[911]: eth0 {newlink} index 2 address B8:27:EB:81:9D:41 mtu 1500
Jan 1 01:00:09 rasplex daemon.info connmand[911]: eth0 {newlink} index 2 operstate 2
Jan 1 01:00:10 rasplex daemon.info connmand[911]: Adding interface eth0 [ ethernet ]
Jan 1 01:00:10 rasplex daemon.info connmand[911]: wlan0 {create} index 3 type 1
Jan 1 01:00:10 rasplex daemon.info connmand[911]: wlan0 {update} flags 4098
Jan 1 01:00:10 rasplex daemon.info connmand[911]: wlan0 {newlink} index 3 address 00:13:EF:F0:00:06 mtu 1500
Jan 1 01:00:10 rasplex user.info kernel: [ 10.116771] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
Jan 1 01:00:10 rasplex user.info kernel: [ 10.117458] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Jan 1 01:00:10 rasplex daemon.info connmand[911]: wlan0 {newlink} index 3 operstate 2
Jan 1 01:00:10 rasplex daemon.info connmand[911]: Adding interface wlan0 [ wifi ]
Jan 1 01:00:10 rasplex daemon.info connmand[911]: eth0 {update} flags 36867
Jan 1 01:00:10 rasplex daemon.info connmand[911]: eth0 {newlink} index 2 address B8:27:EB:81:9D:41 mtu 1500
Jan 1 01:00:10 rasplex daemon.info connmand[911]: eth0 {newlink} index 2 operstate 2
Jan 1 01:00:10 rasplex daemon.notice dbus[851]: [system] Successfully activated service 'net.connman.vpn'
Jan 1 01:00:10 rasplex daemon.info connman-vpnd[1035]: Connection Manager VPN daemon version 1.18
Jan 1 01:00:10 rasplex daemon.info connman-vpnd[1035]: lo {newlink} index 1 operstate 0
Jan 1 01:00:10 rasplex daemon.info connman-vpnd[1035]: eth0 {create} index 2 type 1
Jan 1 01:00:10 rasplex daemon.info connman-vpnd[1035]: eth0 {update} flags 36867
Jan 1 01:00:10 rasplex daemon.info connman-vpnd[1035]: eth0 {newlink} index 2 address B8:27:EB:81:9D:41 mtu 1500
Jan 1 01:00:10 rasplex daemon.info connman-vpnd[1035]: eth0 {newlink} index 2 operstate 2
Jan 1 01:00:10 rasplex daemon.info connman-vpnd[1035]: wlan0 {create} index 3 type 1
Jan 1 01:00:10 rasplex daemon.info connman-vpnd[1035]: wlan0 {update} flags 4098
Jan 1 01:00:10 rasplex daemon.info connman-vpnd[1035]: wlan0 {newlink} index 3 address 00:13:EF:F0:00:06 mtu 1500
Jan 1 01:00:10 rasplex daemon.info connman-vpnd[1035]: wlan0 {newlink} index 3 operstate 2
Jan 1 01:00:10 rasplex daemon.notice dbus[851]: [system] Successfully activated service 'fi.w1.wpa_supplicant1'
Jan 1 01:00:11 rasplex daemon.info connman-vpnd[1035]: eth0 {update} flags 102467
Jan 1 01:00:11 rasplex daemon.info connman-vpnd[1035]: eth0 {newlink} index 2 address B8:27:EB:81:9D:41 mtu 1500
Jan 1 01:00:11 rasplex daemon.info connman-vpnd[1035]: eth0 {newlink} index 2 operstate 6
Jan 1 01:00:11 rasplex daemon.info connmand[911]: eth0 {add} route ff00:: gw :: scope 0
Jan 1 01:00:11 rasplex daemon.info connmand[911]: eth0 {add} route fe80:: gw :: scope 0
Jan 1 01:00:11 rasplex daemon.info connmand[911]: eth0 {update} flags 102467
Jan 1 01:00:11 rasplex daemon.info connmand[911]: eth0 {newlink} index 2 address B8:27:EB:81:9D:41 mtu 1500
Jan 1 01:00:11 rasplex daemon.info connmand[911]: eth0 {newlink} index 2 operstate 6
Jan 1 01:00:11 rasplex user.info kernel: [ 11.538607] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Jan 1 01:00:11 rasplex user.info kernel: [ 11.546691] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x41E1
Jan 1 01:00:12 rasplex daemon.warn connmand[911]: Skipping disconnect of carrier, network is connecting.
Jan 1 01:00:12 rasplex daemon.info connmand[911]: Setting domainname to Home
Jan 1 01:00:12 rasplex daemon.info avahi-daemon[995]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.1.5.
Jan 1 01:00:12 rasplex daemon.info avahi-daemon[995]: New relevant interface eth0.IPv4 for mDNS.
Jan 1 01:00:12 rasplex daemon.info avahi-daemon[995]: Registering new address record for 192.168.1.5 on eth0.IPv4.
Jan 1 01:00:12 rasplex daemon.info connmand[911]: eth0 {add} address 192.168.1.5/16 label eth0 family 2
Jan 1 01:00:12 rasplex daemon.info connmand[911]: eth0 {add} route 192.168.0.0 gw 0.0.0.0 scope 253
Jan 1 01:00:12 rasplex daemon.info connmand[911]: eth0 {add} route 192.168.1.1 gw 0.0.0.0 scope 253
Jan 1 01:00:12 rasplex daemon.info connmand[911]: eth0 {add} route 0.0.0.0 gw 192.168.1.1 scope 0
Jan 1 01:00:12 rasplex user.notice Boot: ### Wait for udevadm settle to finish ###
Jan 1 01:00:12 rasplex daemon.info connmand[911]: eth0 {del} route fe80:: gw :: scope 0
Jan 1 01:00:12 rasplex daemon.info connmand[911]: eth0 {del} route ff00:: gw :: scope 0
Jan 1 01:00:12 rasplex daemon.info connmand[911]: ntp: time slew +1407411328.685237 s
Aug 7 12:35:40 rasplex user.info kernel: [ 12.310368] Console: switching to colour dummy device 80x30
Aug 7 12:35:55 rasplex user.notice Boot: ### set cpu's to 'ondemand' ###
Aug 7 12:36:30 rasplex cron.err crond[822]: time disparity of 23456856 minutes detected
Aug 7 12:36:38 rasplex user.info kernel: [ 70.345775] ieee80211 phy0: rt2x00lib_request_firmware: Info - Loading firmware file 'rt2870.bin'
Aug 7 12:36:38 rasplex user.info kernel: [ 70.374785] ieee80211 phy0: rt2x00lib_request_firmware: Info - Firmware detected - version: 0.29
Aug 7 12:36:39 rasplex daemon.info connman-vpnd[1035]: wlan0 {update} flags 4163
Aug 7 12:36:39 rasplex daemon.info connman-vpnd[1035]: wlan0 {newlink} index 3 address 00:13:EF:F0:00:06 mtu 1500
Aug 7 12:36:39 rasplex daemon.info connman-vpnd[1035]: wlan0 {newlink} index 3 operstate 0
Aug 7 12:36:39 rasplex daemon.info connman-vpnd[1035]: wlan0 {update} flags 4099
Aug 7 12:36:39 rasplex daemon.info connman-vpnd[1035]: wlan0 {newlink} index 3 operstate 5
Aug 7 12:36:39 rasplex daemon.info connmand[911]: wlan0 {update} flags 4163
Aug 7 12:36:39 rasplex daemon.info connmand[911]: wlan0 {newlink} index 3 address 00:13:EF:F0:00:06 mtu 1500
Aug 7 12:36:39 rasplex daemon.info connmand[911]: wlan0 {newlink} index 3 operstate 0
Aug 7 12:36:39 rasplex daemon.info connmand[911]: wlan0 {update} flags 4099
Aug 7 12:36:39 rasplex user.info kernel: [ 70.853430] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Aug 7 12:36:39 rasplex daemon.info connman-vpnd[1035]: wlan0 {newlink} index 3 operstate 2
Aug 7 12:36:39 rasplex daemon.info connmand[911]: wlan0 {newlink} index 3 operstate 5
Aug 7 12:36:39 rasplex daemon.info connmand[911]: wlan0 {newlink} index 3 operstate 2
Aug 7 12:37:11 rasplex daemon.warn connmand[911]: Skipping disconnect of 4669667465656e_managed_psk, network is connecting.
Aug 7 12:37:13 rasplex user.info kernel: [ 105.179334] wlan0: authenticate with fc:f5:28:fa:c1:43
Aug 7 12:37:13 rasplex user.info kernel: [ 105.245126] wlan0: send auth to fc:f5:28:fa:c1:43 (try 1/3)
Aug 7 12:37:13 rasplex user.info kernel: [ 105.257921] wlan0: authenticated
Aug 7 12:37:13 rasplex user.info kernel: [ 105.281217] wlan0: associate with fc:f5:28:fa:c1:43 (try 1/3)
Aug 7 12:37:13 rasplex user.info kernel: [ 105.341132] wlan0: RX AssocResp from fc:f5:28:fa:c1:43 (capab=0x411 status=0 aid=3)
Aug 7 12:37:13 rasplex daemon.info connmand[911]: wlan0 {add} route ff00:: gw :: scope 0
Aug 7 12:37:13 rasplex daemon.info connmand[911]: wlan0 {add} route fe80:: gw :: scope 0
Aug 7 12:37:13 rasplex daemon.info connmand[911]: wlan0 {update} flags 69635
Aug 7 12:37:13 rasplex daemon.info connmand[911]: wlan0 {newlink} index 3 address 00:13:EF:F0:00:06 mtu 1500
Aug 7 12:37:13 rasplex daemon.info connmand[911]: wlan0 {newlink} index 3 operstate 5
Aug 7 12:37:13 rasplex user.info kernel: [ 105.367938] wlan0: associated
Aug 7 12:37:13 rasplex user.info kernel: [ 105.368151] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Aug 7 12:37:13 rasplex daemon.info connman-vpnd[1035]: wlan0 {update} flags 69635
Aug 7 12:37:13 rasplex daemon.info connman-vpnd[1035]: wlan0 {newlink} index 3 address 00:13:EF:F0:00:06 mtu 1500
Aug 7 12:37:13 rasplex daemon.info connman-vpnd[1035]: wlan0 {newlink} index 3 operstate 5
Aug 7 12:37:15 rasplex daemon.info avahi-daemon[995]: Registering new address record for fe80::213:efff:fef0:6 on wlan0.*.
Aug 7 12:37:17 rasplex daemon.info connmand[911]: wlan0 {update} flags 4099
Aug 7 12:37:17 rasplex user.info kernel: [ 108.449064] wlan0: disassociated from fc:f5:28:fa:c1:43 (Reason: 2)
Aug 7 12:37:17 rasplex daemon.info connman-vpnd[1035]: wlan0 {update} flags 4099
Aug 7 12:37:17 rasplex daemon.info connman-vpnd[1035]: wlan0 {newlink} index 3 address 00:13:EF:F0:00:06 mtu 1500
Aug 7 12:37:17 rasplex daemon.info connman-vpnd[1035]: wlan0 {newlink} index 3 operstate 2
Aug 7 12:37:17 rasplex daemon.info connmand[911]: wlan0 {newlink} index 3 address 00:13:EF:F0:00:06 mtu 1500
Aug 7 12:37:17 rasplex daemon.info connmand[911]: wlan0 {newlink} index 3 operstate 2
Aug 7 12:37:17 rasplex user.info kernel: [ 108.523067] wlan0: deauthenticating from fc:f5:28:fa:c1:43 by local choice (reason=3)
Aug 7 12:37:17 rasplex user.info kernel: [ 108.524497] cfg80211: Calling CRDA for country: CH
Aug 7 12:37:53 rasplex daemon.warn connmand[911]: Skipping disconnect of 313743522d524650_managed_psk, network is connecting.
Aug 7 12:37:55 rasplex user.info kernel: [ 146.509706] wlan0: authenticate with 7c:4c:a5:de:4d:ad
Aug 7 12:37:55 rasplex user.info kernel: [ 146.570868] wlan0: send auth to 7c:4c:a5:de:4d:ad (try 1/3)
Aug 7 12:37:55 rasplex user.info kernel: [ 146.572763] wlan0: authenticated
Aug 7 12:37:55 rasplex user.info kernel: [ 146.611233] wlan0: associate with 7c:4c:a5:de:4d:ad (try 1/3)
Aug 7 12:37:55 rasplex user.info kernel: [ 146.614728] wlan0: RX AssocResp from 7c:4c:a5:de:4d:ad (capab=0x411 status=0 aid=4)
Aug 7 12:37:55 rasplex user.info kernel: [ 146.630860] wlan0: associated
Aug 7 12:37:55 rasplex daemon.info connman-vpnd[1035]: wlan0 {update} flags 69635
Aug 7 12:37:55 rasplex daemon.info connman-vpnd[1035]: wlan0 {newlink} index 3 address 00:13:EF:F0:00:06 mtu 1500
Aug 7 12:37:55 rasplex daemon.info connman-vpnd[1035]: wlan0 {newlink} index 3 operstate 5
Aug 7 12:37:55 rasplex daemon.info connmand[911]: wlan0 {RX} 1 packets 135 bytes
Aug 7 12:37:55 rasplex daemon.info connmand[911]: wlan0 {TX} 0 packets 0 bytes
Aug 7 12:37:55 rasplex daemon.info connmand[911]: wlan0 {update} flags 69635
Aug 7 12:37:55 rasplex daemon.info connmand[911]: wlan0 {newlink} index 3 address 00:13:EF:F0:00:06 mtu 1500
Aug 7 12:37:55 rasplex daemon.info connmand[911]: wlan0 {newlink} index 3 operstate 5
Aug 7 12:38:03 rasplex daemon.info connman-vpnd[1035]: wlan0 {update} flags 4099
Aug 7 12:38:03 rasplex daemon.info connman-vpnd[1035]: wlan0 {newlink} index 3 address 00:13:EF:F0:00:06 mtu 1500
Aug 7 12:38:03 rasplex daemon.info connman-vpnd[1035]: wlan0 {newlink} index 3 operstate 2
Aug 7 12:38:03 rasplex daemon.info connmand[911]: wlan0 {RX} 8 packets 1080 bytes
Aug 7 12:38:03 rasplex daemon.info connmand[911]: wlan0 {TX} 8 packets 1240 bytes
Aug 7 12:38:03 rasplex daemon.info connmand[911]: wlan0 {update} flags 4099
Aug 7 12:38:03 rasplex daemon.info connmand[911]: wlan0 {newlink} index 3 address 00:13:EF:F0:00:06 mtu 1500
Aug 7 12:38:03 rasplex daemon.info connmand[911]: wlan0 {newlink} index 3 operstate 2
Aug 7 12:38:03 rasplex user.info kernel: [ 154.786967] wlan0: deauthenticated from 7c:4c:a5:de:4d:ad (Reason: 15)
Aug 7 12:38:03 rasplex user.info kernel: [ 154.856691] cfg80211: Calling CRDA to update world regulatory domain
Aug 7 12:38:17 rasplex user.info kernel: [ 169.296511] wlan0: authenticate with 7c:4c:a5:de:4d:ad
Aug 7 12:38:17 rasplex user.info kernel: [ 169.360846] wlan0: send auth to 7c:4c:a5:de:4d:ad (try 1/3)
Aug 7 12:38:17 rasplex user.info kernel: [ 169.364182] wlan0: authenticated
Aug 7 12:38:17 rasplex user.info kernel: [ 169.371488] wlan0: associate with 7c:4c:a5:de:4d:ad (try 1/3)
Aug 7 12:38:17 rasplex user.info kernel: [ 169.375072] wlan0: RX AssocResp from 7c:4c:a5:de:4d:ad (capab=0x411 status=0 aid=4)
Aug 7 12:38:17 rasplex daemon.info connman-vpnd[1035]: wlan0 {update} flags 69635
Aug 7 12:38:17 rasplex daemon.info connman-vpnd[1035]: wlan0 {newlink} index 3 address 00:13:EF:F0:00:06 mtu 1500
Aug 7 12:38:17 rasplex daemon.info connman-vpnd[1035]: wlan0 {newlink} index 3 operstate 5
Aug 7 12:38:17 rasplex user.info kernel: [ 169.389454] wlan0: associated
Aug 7 12:38:17 rasplex daemon.info connmand[911]: wlan0 {RX} 9 packets 1215 bytes
Aug 7 12:38:18 rasplex daemon.info connmand[911]: wlan0 {TX} 8 packets 1240 bytes
Aug 7 12:38:18 rasplex daemon.info connmand[911]: wlan0 {update} flags 69635
Aug 7 12:38:18 rasplex daemon.info connmand[911]: wlan0 {newlink} index 3 address 00:13:EF:F0:00:06 mtu 1500
Aug 7 12:38:18 rasplex daemon.info connmand[911]: wlan0 {newlink} index 3 operstate 5
Aug 7 12:38:26 rasplex daemon.info connmand[911]: wlan0 {RX} 16 packets 2160 bytes
Aug 7 12:38:26 rasplex daemon.info connmand[911]: wlan0 {TX} 16 packets 2480 bytes
Aug 7 12:38:26 rasplex daemon.info connmand[911]: wlan0 {update} flags 4099
Aug 7 12:38:26 rasplex daemon.info connmand[911]: wlan0 {newlink} index 3 address 00:13:EF:F0:00:06 mtu 1500
Aug 7 12:38:26 rasplex daemon.info connmand[911]: wlan0 {newlink} index 3 operstate 2
Aug 7 12:38:26 rasplex user.info kernel: [ 177.558982] wlan0: deauthenticated from 7c:4c:a5:de:4d:ad (Reason: 15)
Aug 7 12:38:26 rasplex daemon.info connman-vpnd[1035]: wlan0 {update} flags 4099
Aug 7 12:38:26 rasplex daemon.info connman-vpnd[1035]: wlan0 {newlink} index 3 address 00:13:EF:F0:00:06 mtu 1500
Aug 7 12:38:26 rasplex daemon.info connman-vpnd[1035]: wlan0 {newlink} index 3 operstate 2
Aug 7 12:38:26 rasplex user.info kernel: [ 177.624788] cfg80211: Calling CRDA to update world regulatory domain
Aug 7 12:52:44 rasplex daemon.info connmand[911]: ntp: time slew -0.032039 s
