Burn subtitles - why not Automatic on default ??
Hi. I have noticed the default setting in the player for Burn Subtitles is Always . That means the subtitle will be incastrated into the image, that means transcoding. That means high CPU etc etc etc…
I do not understand why the default subtitle setting is not automatic , to be able to use direct play or direct stream…
If you could correct this in the next version of plex it would be awsome…
bump…
buuuuumpppp
The default preference has been changed to ‘Automatic’.
You just need to use the latest web client. http://plex.tv/web
