@kdackiw said:
“Billy Joel - Songs In The Attic (MFSL) (DSD64)”
This is my folder name and I embed this name into the tags as the album name.
IMHO the Album name should not contain the Artist name.
There is a separate metatag for the Album Artist.
I need to differentiate the formats since hi-res has a few formats and I prefer DSD over PCM.
Hint: There is not a single Plex client able to decode DSD itself. So you will always hear the audio which the Plex transcoder a) decoded DSD to PCM and then b) transcoded to MP3 or OPUS (depending on which type of client you use) and then sent to the client.
Even if some clients were able to decode DSD, probably none of them has a DA converter able to handle DSD, as this requires a fundamentally different circuitry in the converter. The sonic advantage of DSD will only reach your ears if such a special DA converter is used.
In almost all cases, the DSD data is computationally converted to PCM and then sent to conventional DA converters - hence the sonic advantage is lost.
But that just as an aside.
Everything I previously said about embedded metadata is not valid for DSF files, since Plex cannot read metadata from them.
Plex definitely does not grab the folder name and the track names verbatim. Looking through my collection, it appears to prefer the internet naming over my tags. I have verified this with other folders. Characters that would be illegal (:, etc.) that are periods in my filenames become colons again in Plex.
What type of music library do you have?
Have you moved the ‘Local Media Assets’ to the top in every library type? (there are 3, ‘Personal Media Albums’, ‘Plex Premium Music’, ‘Last.fm’ )
It looks like it mostly? grabbed the cover art however as that changed from my last scan. It is still not 100% grabbing any “folder.jpg” images or the embedded cover art in the files.
What server platform are we talking about? Is this Linux, Mac, Windows, Linux, NAS?
There are a few pitfalls for the Local Media Assets agent when it comes to non-ascii characters in folder and file names on some Linux-based platforms.
Which file types did you test. Only .dsfor others too?
