Cable not found
Server Version#: 1.24.2.5000
Player Version#: all
Tuner Make/Model: model 01657: WinTV-dualHD Live TV for Cordcutters
Guide/Lineup name: none
Using XMLTV?: none
Channel number/Name:
hi so hears whats going on i bout a tuner for my plexserver i then got a antana i loves the antana but my dad dint like we only got 60 channels so i got spectrum tv cable from spectrum but when i try to set up my live tv and dvr my tuner says that it tuned in to 269 canels but when i sulect anay of the tree spectrum epg seting nothing matches up it just says that the canels are protected
That version was withdrawn due to problems. Uninstall and download the current version and try. Plex Media Server - #460 by emilybersin
Even if you had the Cable Card version(which you don’t) you would have to check with Spectrum to see which/if any channels are sent in the clear.
Clear QAM is digital cable TV
Clear QAM allows users to watch unencrypted HDTV stations from cable TV without a set-top box. Clear QAM does require a cable TV subscription. Clear QAM TV is not available on all cable networks, so check with your local cable TV operator for clear QAM availability.
