I’ve had a look at the caldera headless prefs - there are no equaliser config options there. Plexamp headless offered a 10-band graphical EQ. The Caldera page suggests there is a parametric EQ available.
How to configure this, and is this really a parametric EQ or just a misnomer for a graphical one?
Q is a fixed 1.41 per band (≈ 1 octave), not derived from frequency, but with octave-spaced centers it gives constant-Q behavior, so effective bandwidth in Hz is proportional to each band’s center frequency.
Does the equalizer set from Plexamp on an iPhone remain permanently activated on the Apple TV client, or does it only work when we start playback from that iPhone?
That’s what I thought, but I was confused because when disconnecting Plexamp from Caldera on Apple TV and reconnecting again, it doesn’t show the previously set equalization.
