PLEXAMP - Where is the parametric EQ?
I’m trying to find where is the parametric EQ on the android plexamp app.
I can only find a fixed band graphic eq.
With a parametric EQ you are supposed to be able to add bands and edit the frequency, the slope (Q factor) and the magnitude (dB).
I think we called it that somewhere by mistake.
It says it right on the home page for plexamp lol.
Super audio player
“Loudness leveling, true gapless playback, Sweet Fades™, soft transitions, a configurable preamp, a parametric EQ, and more.”
But yeah standard definition of a parametric EQ is an EQ with parameters such as frequency and Q.
Gain is a given, obviously.
I wish Plex would indeed add a parametric EQ to Plexamp. It can’t be that hard. Surely there is some library they can add in to do it.
The good news is that apparently Plexamp supports PEQ under the hood.
They just need to expose it via a GUI update.
