Camera upload [Android] - Albums View empty on Chrome [Plex Web]
I have created two separate albums for uploading camera pictures on Android.
The feature works great, and I can view all the pictures in the timeline on the web (using chrome).
The only problem is when I select the ‘Albums’ view, message appears ‘Nothing to see here’
although in the regular ‘Photos’ view, I can see both folders created as ‘Albums’ properly, and also see all the images in the ‘Timeline’ view. (see picture, both albums appear as folders).
‘Albums’ are actually ‘Playlists,’ renamed for photos. You have to manually add the photos you want to an album, then the album will appear in ‘Albums’ view, and also on the Playlists page (although that might change).
You can add entire folders, or individual photos, to an album by clicking the ‘…’ menu and selecting ‘Add to Album’.
Thank you. That makes sense now!
I assume the new uploaded pictures won’t be added automatically to the albums I created, right?
I haven’t tried this, but if you make it a smart album/playlist, it should work.
Here’s what I did:
In my Photography Library, I created a Custom Filter as follows:
After applying that filter, click on Add to Album:
Give the album a name, and it creates a smart album/playlist. If it works like it should, any photo uploaded from that model of phone should automatically be added to the album.
